Logitech MX ERGO Wireless Trackball Mouse
Quicklinx: D8NKWS00 Mfr#: 910-005179
Recommended Use: Leisure
Type: Mouse, Trackball
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC
17 In Stock
£66.51 ex VAT
£79.81 inc VAT
Logitech's advanced trackball for trackball enthusiasts and consumers, searching for alternatives to mice and touchpads. Delivers less muscular strain. MX ERGO features a unique adjustable hinge for personalized comfort and the tracking, scrolling and power management technology. Logitech FLOW enables effortless cross computer control.
  • Customized comfort
    Finally a trackball you can truly call your own. A unique adjustable hinge allows you to choose the best angle between 0°and 20° for a more natural hand position and greater comfort
  • Advanced tracking and precision mode button
    Change the speed and accuracy of your cursor for optimal control with a press of a button
  • Precision scroll wheel with tilt
    Get things done faster with quick access to shortcuts. The precision scroll wheel features horizontal scrolling and a convenient middle click
  • Effortless Multi-Computer Workflow
    Connect and work on two devices at the same time and easily switch between them. Boost your cross-computer experience with Logitech FLOW technology. Copy and paste text, images and files between computers
  • Long-lasting and fast rechargeable battery
    Battery holds power for up to 4 months on a full charge. One minute of charge gives up to a full day of use
Logitech MX ERGO - trackball - Bluetooth, 2.4 GHz
Trackball
Wireless - Bluetooth, 2.4 GHz
9.98 cm x 13.25 cm x 5.14 cm
259 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
8
Movement Resolution
440 dpi
Scrolling wheel, Logitech Advanced Optical Tracking
Microsoft Windows 7 / 8 / 10, Apple macOS 10.12
Trackball
Wireless Receiver
9.98 cm
13.25 cm
5.14 cm
259 g
Input Device
Wireless
Bluetooth, 2.4 GHz
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
8
Movement Resolution
440 dpi
1 x USB - 4 pin USB Type A
Micro-USB cable
Lithium polymer
500 mAh
Run Time (Up To)
4 months
Type: Mouse
Type: Trackball
Colour: Black
Compatibility: PC
Brand: Logitech
