UE MINI BOOM is the powerful and stylish portable Bluetooth speaker with unexpectedly huge sound for its surprisingly small size.
Strong and punchy
Don't be fooled by it's small size. UE MINI BOOM delivers bold confident sound with colorful attitude. Enjoy your favorite songs with crystal clear highs and strong balance all the way down to the bass. -
Colorful and stylish
Choose from five fun color combinations. Use the color selector to find the UE MINI BOOM that fits your style. -
Play out loud
Whether you're traveling, hanging with friends outdoors, or just kicking back and watching a concert on your tablet at home, UE MINI BOOM is the perfect companion for a life of play. -
Compact design
UE MINI BOOM was designed to easily fit in your backpack, purse, gym bag, or to even just be tossed into your car - it was designed to be taken everywhere. -
Simple controls
Large +/- buttons make adjusting the volume a snap and the multifunction button makes it easy to answers calls and connect new Bluetooth devices. -
Crystal clear speakerphone
Take calls in confidence with the reliable clarity and connectivity of UE MINI BOOM. Your new office is everywhere. -
Better wireless
UE MINI BOOM pumps out up to 10 hours of huge sound and wirelessly streams music from Bluetooth enabled devices from up to 50 ft away. Farther than most other wireless Bluetooth speakers. -
10 hour battery
UE MINI BOOM features a rechargeable lithium-ion battery with up to 10 hours of continuous music on a single charge. Conveniently recharge on the go with the included micro USB cable. -
50 ft Bluetooth wireless
UE MINI BOOM can connect to your Bluetooth enabled devices from up to 50 ft away, can be actively paired to any two devices at once and will remember the last 8 devices it connected to. -
NFC enabled
Use a simple tap to connect your UE MINI BOOM to NFC-enabled devices. -
Double up
Life is better when friends come together. Wirelessly connect two UE MINI BOOMs together with the UE BOOM app to take the music and energy to a new level. -
Stereo mode
Connect the two speakers in 'Stereo' for when you want to enjoy epic stereo sound with wide separation. -
Double mode
When you want the two speakers to play the same thing choose 'Double' and enjoy the same stream from both speakers.
- Ultimate Ears MINI BOOM - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Frequency Response
- 130 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth, NFC
- Speaker System Details
- 1 x speaker 130 - 20000 Hz
- Purple
- Power Options
- USB powered
- Battery
- Speaker battery rechargeable - Lithium Ion
- 11.1 cm x 6.6 cm x 6.1 cm
- 301 g
- 2-year warranty
- Product Type
- Hands-Free Function
- Enclosure Colour
- Purple
Speaker System
- Speaker Type
- Active
- 130 - 20000 Hz
- Max Output Level (Max SPL)
- 86 dB
- Amplifier
- Integrated
- Bluetooth, Near Field Communication (NFC)
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
- Transmission Range
- 15 m
- Controls
- Power on/off, volume
- Speakers Included
- 1 x speaker - 130 - 20000 Hz - wireless
- Driver Details
- Portable speaker: 2 x full-range driver - 1.5" , Portable speaker: Passive Radiator - 3" x 1.5"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Micro-USB cable
- Power Source
- Battery
- Options
- USB powered
- Rechargeable - Lithium Ion
- Run Time (Up To)
- 10 hour(s)
- 11.1 cm
- 6.6 cm
- 6.1 cm
- 301 g
- Limited warranty - 2 years
