Logitech M100 Mouse - 3 Buttons USB Wired
Mouse M100
Quicklinx: 746FWS00 Mfr#: 910-001602
Logitech Mouse M100 gives you just the basics for comfortable, reliable control of your computer. There is no software to install. And since it is corded, you can just plug the cable into a USB port and use it right away. The full-size, ambidextrous shape means your hand will rest comfortably, while high-definition optical tracking (1000 dpi) means you will get responsive, smooth cursor control for precise tracking and easy text selection.
  • Simple to set up and use
    Setup is fast and easy-just plug the cable into a USB port. There's no software to install. And since it's corded, you can just plug the cable into a USB port and use it right away
  • Full-size comfort, ambidextrous design
    Designed to keep either hand happy. So you'll feel comfortable, even after hours of use
  • High-definition optical tracking
    You'll enjoy responsive, smooth cursor control and precise tracking and easy text selection thanks to high-definition optical tracking (1000 dpi)
  • Built by Logitech
    This mouse comes with the quality and design we've built into more than a billion mice, more than any other manufacturer
Logitech M100 - mouse - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
6.1 cm x 11.2 cm x 3.9 cm
64 g
Western Europe
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel
Apple MacOS X 10.4 or later, Linux Kernel 2.6.x or later, Microsoft Windows Vista / XP / 7
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Orientation
6.1 cm
11.2 cm
3.9 cm
64 g
Western Europe
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel
1 x USB - 4 pin USB Type A
Additional Requirements
USB port
Limited warranty - 3 years
