Video collaboration for small meeting spaces, private rooms, and focus rooms. Features clear audio, pro video, one touch meetings, simple installation, & more.
Cable management
An included mounting bracket and cable tidy kit attach Logi Dock to the table in a clean and secure manner. -
Flexible installation
Confidently deploy the kit at scale with multiple table mounting options. -
Noise-canceling speakerphone
Six beamforming microphones help capture your voice clearly while advanced algorithms reduce unwanted background noise. -
Crystal-clear sound
Expertly-tuned speakers deliver crystal-clear sound for video meetings. -
One-touch meeting controls
Control audio and video, and join any meeting with a single touch. -
Connect everything
Attach up to five USB peripherals via USB-A and USB-C, and up to two monitors via HDMI and DisplayPort. Connect to wired networks via the included USB-C-to-Ethernet adapter. -
Bluetooth connectivity
Pair to a smartphone or tablet via Bluetooth to stream audio. -
Ultra-HD video
Enable immersive face-to-face conversations with 5x HD zoom in clear 4K resolution. -
Look natural in any light
Logitech RightLight and high dynamic range (HDR) technology capture natural-looking skin tones, even in dim or backlit conditions. -
Adjustable field of view
Choose from three diagonal field of view presets - 65°, 78° or 90° to perfectly frame your video.
- Logitech Logi Dock Focus Room Kit - video conferencing kit
- Video conferencing kit
- Kit Content
- Logitech BRIO Ultra HD Pro Webcam, Logitech Logi Dock
- Video Input
- Digital camera - SuperSpeed USB 3.0
- Audio Input
- 6-microphone array - beamforming
- Audio Output
- Speaker(s)
- Input Device
- Control buttons
- Networking
- Bluetooth
- Software Certification
- Certified for Microsoft Teams
- System Requirements
- Android, Google Chrome OS, Apple iOS, Windows 10 or later, Apple macOS 11 or later
- 2-year warranty
- Kit Content
- Dimensions & Weight Details
- Docking station with bracket - Width 16 cm Depth 20.7 cm Height 8.8 cm Weight 1.095 kg , Web camera - Width 10.2 cm Depth 2.7 cm Height 2.7 cm Weight 63 g
Video Input
- Digital camera (colour) - external
- Interface Type
- Digital Video Capture Resolution
- 1280 x 720, 1920 x 1080, 4096 x 2160
- Video Modes
- 720p, 1080p, 4K
- Digital Zoom
- 5
- High Dynamic Range (HDR), 4K ULTRA HD engine, Auto Focus, RightLight 3 technology, noise-cancellation, 52.2° field of view (vertical), 82.1° field of view (horizontal), 90° diagonal field of view, Windows Hello compatible, 13 megapixels resolution, glass lens
Audio Input
- 6-microphone array - integrated
- Microphone Operation Mode
- Beamforming
- Frequency Response
- 65 - 8000 Hz
Audio Output
- Speaker(s)
- 60 - 20000 Hz
Input Device
- Control buttons
- Connectivity Technology
- Wireless, wired
- Data Link Protocol
- Bluetooth
- Cable management, security slot (Kensington security lock compatible)
- 1 x audio / video - HDMI , 1 x audio / video - DisplayPort , 2 x USB 3.1 Gen 1 - 9 pin USB Type A , 3 x USB 3.1 Gen 1 - 24 pin USB-C , 1 x USB-C Upstream with Power Delivery (100 W)
- Cables Included
- 1 x USB to USB-C cable - 2.2 m , 1 x USB-C cable - 1 m
- Included Accessories
- Mounting bracket, privacy shutter, cable management hardware, USB-C cable tidy kit, USB-C cable, USB to USB-C cable, USB-C to ethernet adapter
- Plug and Play, DisplayPort 1.4
- Power Device
- Power adapter - external
- OS Required
- Limited warranty - 2 years
