Your Harmony remote already controls the most important pieces of your home-entertainment environment with one notable exception - your PLAYSTATION 3. The Logitech Harmony Adapter for PLAYSTATION 3 works with your Harmony remote, so you get a single remote that controls your entire home entertainment system.
Works with Logitech Harmony remotes
No compatibility worries. Your PLAYSTATION 3 Adapter is designed to work with your Logitech Harmony remote. -
Supports all 51 PLAYSTATION 3 commands
Supports all 51 PLAYSTATION 3 commands: control your DVD and Blu-Ray Disc movies, navigate the XrossMediaBar (XMB) and even power your PLAYSTATION 3 on and off without using your game controller. -
Compact, low-profile design
No extra clutter. The adapter blends discreetly into your home-entertainment environment. -
Guided online setup
You connect your Harmony remote to your computer and you're guided through every step. If you hit a snag, customer support is ready to help. -
Always on, wireless link
This adapter uses AC power and a Bluetooth wireless connection to communicate with your PLAYSTATION 3. So, your remote works whether your console is on or off. And your valuable USB ports remain available for more other controllers.
- Logitech Harmony Adapter for PLAYSTATION 3 - adapter for remote control
- Product Type
- Adapter
- Intended For
- Remote control
- Designed For
- Sony PlayStation 3
- Product Type
- Adapter
- Intended For
- Remote control
- Compatible Game Consoles
- Designed For
