Logitech Expansion Mic for MeetUp
Quicklinx: D466WS00 Mfr#: 989-000405
25 In Stock
£179.12 ex VAT
£214.94 inc VAT
Standard delivery Delivered within 3-5 working days
Logitech Expansion Mic extends the range of a video conferencing system and comfortably allow people to collaborate in one large room.
  • HEAR CLEARLY UP TO 4.2 METERS
    Because huddle rooms vary in size, we created Expansion Mic to provide additional flexibility in different room configurations. Expansion Mic extends MeetUp's microphone pickup range to 4.2 meters
  • EASILY MUTE CALLS
    A microphone mute button lets those at the far end of the table mute the entire speakerphone system. The indicator light shows when the microphone is muted, when a call is active, and when Bluetooth wireless pairing has begun
Logitech EXPANSION MIC FOR MEETUP - microphone
Microphone
Recommended Use
Conference
Microphone Operation Mode
Mono
Microphone Noise Cancelling
Small Room Solution for Google Meet, for Microsoft Teams Rooms, for Zoom Rooms
Microphone
8.3 cm
8.3 cm
1.34 cm
302 g
Recommended Use
Conference
Max Operating Distance
4.2 m
Microphone
Mono
Wired
Noise Cancelling
Mute function
Cable Details
Microphone cable - 6 m
Logitech Small Room Solution for Google Meet, for Microsoft Teams Rooms, for Zoom Rooms
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: D466 046003
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £24.44
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Logitech
Stock Status: Used Stock
