Logitech Crayon is a versatile, pixel-precise digital pencil for all iPads (2018 and later) that lets you unleash your creativity. Mark up PDFs, take handwritten notes, or doodle a masterpiece - Logitech Crayon works with apps that support Apple Pencil. And with hundreds of Apple Pencil supported apps available right now, you can start learning, collaborating, and creating on iPad instantly.
DIGITAL LEARNING
Unleash what's possible for students of all ages using innovative educational apps. Crayon empowers them to write, create, and learn at home or in the classroom - and yes, that includes lefties! -
WORK PROFESSIONALS
Step up your work game with a tool that allows you to supercharge your productivity whether you're working from home, or back in the office -
UPGRADE YOUR NEXT PROJECT
Stop settling for average, unleash your creativity and bring personal projects to the next level with Logitech Crayon -
PRECISELY ON POINT
With zero perceptible lag time and precision down to the pixel, just write and draw naturally without fear of missing a single line or detail -
THE PERFECT LINE EVERY TIME
Need a thicker or thinner line? Just tilt. A smart tip dynamically adjusts line weight depending on the angle you place it down - just like a regular pencil -
University Students
Take lecture notes, sketch lab diagrams, and collaborate remotely -
Middle & High School
Toss it in a backpack to take class notes, illustrate concepts in STEM classes, or collaborate with classmates -
Elementary
Helps younger students write, draw, and even converts hand-written notes to text with Scribble -
Sign Documents & Markups
Add hand-written signatures to documents for an extra touch of professionality -
Enhance Your Designs
Bring hand-drawn illustration and type to family newsletters, personal websites, and more -
Homemade Gifts
Add a personal touch to DIY projects and crafts with hand-drawn images and logos -
Digital Creation
Get more done with an intuitive analog tool that's easy to grasp and use -
SETUP RESOURCES
Updating iOS on your iPad may affect your ability to enjoy the full functionality of certain apps with Crayon. If you notice changes in your experience, update your Crayon's firmware here -
REPLACEMENT PARTS
Replace a worn down or broken Logitech Crayon tip to ensure you're getting the most from your digital pencil and iPad -
Simple Comfort Possible
Lightweight, comfortable and convenient with easy flip-to-mute feature. Stay cool with open air around your ears
- Logitech Crayon - digital pen - grey
- Digital pen
- Connectivity Technology
- Wireless
- Grey
- 1.2 cm x 0.8 cm x 16.3 cm
- 20 g
- Tilt sensitive, on/off power switch, Palm Rejection Technology, automatic power off, charging LED Indicator, rechargeable battery, 1.2 m drop protection
- 2-year warranty
- Digital pen
- 1.2 cm
- 0.8 cm
- 16.3 cm
- 20 g
- Product Material
- Aluminium, silicone rubber, PC/ABS
- Grey
Input Device
- Wireless
- 1 x Lightning - Apple Lightning
- Technology
- Lithium polymer
- Run Time (Up To)
- 7.5 hour(s)
- Limited warranty - 2 years
