Logitech C922 Pro Stream Webcam
Quicklinx: FW83WS00 Mfr#: 960-001088
Compatibility: PC, Mac
Interface: USB Type-C
£69.74 ex VAT
£83.68 inc VAT
Express delivery Order within the next 24 hours for delivery on Tuesday
Connect with superior clarity every time you go live on channels like Twitch and YouTube. Stream anything you want in your choice of 1080p or fluid HD 720p at 60fps. Broadcast your gameplay in full HD with integrated background replacement (Powered by Personify), reliable no-drop audio, autofocus, and a 78-degree field of view. Includes free 3-month premium XSplit license.
  • DESIGNED FOR SERIOUS STREAMERS
    Connect with superior clarity every time you go live on channels like Twitch and YouTube. Stream anything you want in your choice of Full 1080p at 30fps or hyperfast HD 720p at 60fps. Broadcast masterfully with reliable no-drop audio, autofocus, and a 78° diagonal field of view. Includes free 3-month premium XSplit license
  • FULL HIGH-DEF 1080P STREAMING
    Stream and record vibrant, true-to-life video. C922 features a glass lens with autofocus and a 78° diagonal field of view. Full HD streaming captures all the details, bright, natural colors, and fluid video at 1080p/30fps-and in HD at 720p/30fps. Use Capture to zoom, pan, and edit
  • HYPERFAST FRAME RATE
    Serious streamers need the hyperfast frame rate of 60 fps at 720p for particularly smooth video, and that's just what the C922 delivers. You'll be live broadcasting with no lag or distortion
  • AUTO LIGHT CORRECTION
    HD autofocus and light correction work to fine-tune lighting conditions, producing razor-sharp, high-def video in any lighting, so you always look great in your stream
  • DUAL-MIC STEREO SOUND
    Fitted with two omni-directional microphones, the C922 Pro Webcam captures more realistic sound from multiple angles-so your voice comes through sounding natural and clear in your stream
  • 3-MONTH XSPLIT PREMIUM LICENSE
    All-in-one live streaming solution includes a complete set of features for XSplit Broadcaster and XSplit Gamecaster, giving you everything you need to stream like a pro. 3 month voucher included
  • ALL-IN-ONE CONTENT CREATION WITH CAPTURE
    Easily create, record, and customize settings with our Capture app. A suite of features lets you fully edit and customize your stream, so you can add transitions and text overlays, customize webcam settings, and more
Logitech HD Pro Webcam C922 - webcam
Webcam
9.5 cm x 7.1 cm x 4.35 cm
162 g
Wired
Camera
Frame Rate (max)
60 frames per second
Video Modes
720p, 1080p
Focus Adjustment
Automatic
1-year warranty
Webcam
Wired
9.5 cm
7.1 cm
4.35 cm
162 g
Camera
Digital Video Format
H.264
Video Modes
720p, 1080p
Frame Rate (max)
Lens Construction
Focus Adjustment
Automatic
Limited warranty - 1 year
Compatibility: PC
Compatibility: Mac
Brand: Logitech
