Logitech C505e Webcam - colour - 720p - fixed focal - audio USB
Quicklinx: GDNVWS00 Mfr#: 960-001372
Compatibility: PC
Interface: USB
Hurry, only 1 left in stock!
£37.49 ex VAT
£44.98 inc VAT
Express delivery Delivered on Tuesday
Step up from built-in laptop optics with the Logitech C505e business webcam that delivers crisp, smooth and colorful widescreen HD 720p video making office life much easier.
Logitech business webcam offers high-precision optics with autofocus for remarkable resolution and clarity to help you look your best. With Logitech RightLight, you can be seen clearly in low light and bright sunlight. Plug and Play compatibility means your webcam is simple to use out of the box and performs seamlessly with virtually any video conferencing software.
  • HD 720p WIDESCREEN VIDEO
    Step up from built-in laptop optics with a webcam that delivers crisp, smooth and colorful video quality with widescreen HD 720p/30 fps resolution. C505e provides a 60° diagonal field of view, fixed focus and auto light correction that adjusts to the illumination of your meeting space
  • CLEAR, NATURAL AUDIO
    The single, omnidirectional mic features noise-reduction technology and is engineered to support clear, natural conversation up to 3 meters away, even in busy environments like open workspaces and classrooms
  • 2 M CABLE EXTENDS SETUP OPTIONS
    With its extra-long 2 m USB-A cable and universal clip, C505e offers a wide range of versatile mounting possibilities. Go traditional and position it securely on a laptop or external screen, or get creative and mount it on a shelf or fixture up to 2 m away from your computer
Logitech C505e - webcam
Webcam
Audio
Yes: built-in omni-directional microphone
7.291 cm x 6.664 cm x 3.191 cm
75 g
Wired
Camera
Frame Rate (max)
30 frames per second
Video Modes
720p
Focal Length Control
Fixed focal
USB
1 - USB cable - integrated - 2 m
RightLight 2 technology, Skype for Business compatible, Microsoft Teams compatible, Zoom compatible, Google Voice compatible, Meet compatible, auto light correction, 60° field of view
Webcam
Audio Support
Wired
7.291 cm
6.664 cm
3.191 cm
75 g
Mexico
Camera
Video Modes
720p
Digital Video Capture Resolution
1280 x 720, 720p
Frame Rate (max)
Still Image Capture Resolution
1280 x 720
Lens Construction
Fixed focal
Computer Interface
USB
Ports
USB
Clip mount
1 x USB cable - integrated - 2 m
Compatibility: PC
Interface: USB
Brand: Logitech
