Liebert Liebert Powersure Psp 500VA UPS System
Quicklinx: 7GXRWS00 Mfr#: PSP500MT3-230U
Liebert PSP 500VA is a full featured UPS that delivers cost-effective power protection in a compact package. The UPS provides battery-backed outlets and a surge protection only outlet. The UPS battery offers four minutes of backup power at full load - ample time to shut down protected equipment if an outage occurs.
  • Flexibility
    Provide four battery-backed UPS outlets with space for transformer blocks, and two surge-only outlets. Allow configurable input power selection. Operate with a wider input voltage window.
  • Higher availability
    Provide greater than four minutes of battery backup at full load. Ensure battery availability with full sequenced battery testing. Allow fast and easy maintenance with user-replaceable hot-swappable batteries. Notify users with advance early warning shutdown. Provide lightning and surge protection (TVSS). Protect data lines against surges - telephone/fax/DSL/modem.
Liebert PowerSure PSP - UPS - 300 watt - 500 VA - 7 Ah
UPS - Power Factor Correction (PFC) - external
3.9 kg
Input Wiring
1-phase
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
300 watt / 500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
1 x power IEC 60320 C13 (surge) - 230 V , 3 x power IEC 60320 C13 - 230 V
- 7 Ah - 7 Ah
Batteries Qty
1
Run Time (Up To)
11 min at half load
USB
8.7 cm x 21.5 cm x 25.1 cm
UPS Technology
Off-line
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 287 V
Frequency Provided
50/60 Hz
Input Wiring
1-phase
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V ± 5% - 50/60 Hz
Power Capacity
300 watt / 500 VA
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Power Factor (PF)
0.6
Quantity
1
Voltage Provided
12 V
7 Ah 7 Ah
Run Time (Up To)
11 min at half load
Recharge Time
8 hours
Transfer Time
6 ms
Sealed
Remote Management Interface
USB
1 x USB 2.0 - 4 pin USB Type B
Audible alarm, LED indicators, overload protection, VRLA battery support
IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 62040-1-1, RoHS, EN 62040-1-1, IP20
0 - 90%
8.7 cm
21.5 cm
25.1 cm
3.9 kg
Shipping Width
15.1 cm
Shipping Depth
41.9 cm
Shipping Height
27.9 cm
Shipping Weight
10.6 kg
