For enhanced UPS communications and control, the Liebert IntelliSlot IS-WEBCARD delivers SNMP and web-management communications capability to your Liebert GXT unit. This feature will provide flexibility in how you monitor and control your UPS over the network. The card is also easily configurable to work in a standard SNMP implementation and with Liebert's MultiLink unattended shutdown software.
Enhanced connectivity
With an RJ-45 connector for Ethernet 10Base-T/100Base-TX and a 9-pin D-Sub (DB-9) for RS-232, this Web Card ensures versatile connectivity options for a wide range of networking needs. -
Robust security
Featuring SSL encryption, the Liebert Intellislot Web Card provides a secure platform for managing your devices, ensuring your data remains protected. -
Comprehensive network support
Supports a variety of data link protocols including Ethernet, Fast Ethernet, and RS-232, alongside a data transfer rate of 100 Mbps, making it suitable for high-speed networking environments. -
Efficient management
Equipped with remote management protocols such as HTTP, HTTPS, SNMP 1, SNMP 2c, SNMP 3, and Telnet, this card allows for efficient and flexible management of your networked devices. -
Reliable operation
Designed to operate within a wide range of environmental parameters, including a humidity range of 10 - 90% (non-condensing) and temperatures from 0°C to 55°C, ensuring reliable performance under various conditions.
- Liebert Intellislot Web Card - remote management adapter - Liebert IntelliSlot
- Remote management adapter
- Form Factor
- Plug-in module
- Interface (Bus) Type
- 7.6 cm x 13.4 cm x 3.8 cm
- 200 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, RS-232
- Data Transfer Rate
- 100 Mbps
- Designed For
- Liebert GXT3-1000MT120, GXT3-1000RT120, GXT3-1000RT230, GXT3-1500RT120, GXT3-1500RT230, GXT3-2000RT120, GXT3-2000RT230, GXT3-3000RT120, GXT3-3000RT208, GXT3-3000RT230, GXT3-500RT120, GXT3-700RT120, GXT3-700RT230
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet, RS-232
- 100 Mbps
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS
- Status Indicators
- Power, link OK
- DHCP support, BOOTP support, E-mail alert, firmware upgradable, SMS alert
- 1 x 100Base-TX - RJ-45 , 1 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x Liebert IntelliSlot
- Encryption Algorithm
- SSL
- 1.75 Watt
- 7.6 cm
- 13.4 cm
- 3.8 cm
- 200 g
- 0 °C
- 55 °C
- 10 - 90% (non-condensing)
- Designed For
