The Liebert GXT3 is a compact, online uninterruptible power system (UPS) that continuously conditions and regulates its output voltage. The Liebert GXT3 is designed to supply microcomputers and other sensitive electronic equipment with clean sine wave input power.
Upon generation, AC power is clean and stable. However, during transmission and distribution it is subject to voltage sags, spikes and complete failure that may interrupt computer operations, cause data loss and damage equipment.
The Liebert GXT3 protects equipment from these disturbances. The Liebert GXT3 continuously charges its batteries from the mains, enabling it to supply power to connected loads, even when the mains fail. This section describes the UPS, its features, models, appearance and components, operating principles and operating mode.
- Liebert GXT3-5000RT230 - UPS - 4 kW - 5000 VA
- UPS - Power Factor Correction (PFC) - external
- Rack Size
- 19" - 5U
- 60 kg
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- AC 230 V
- Power Capacity
- 4 kW / 5000 VA
- Input Connectors
- Hardwire
- Output connectors
- 4 x power IEC 60320 C13 , 2 x power IEC 60320 C19 , 1 x hardwire
- Battery
- Lead Acid - 9 Ah
- Batteries Qty
- 20
- Run Time (Up To)
- 8 min at full load
- Networking
- USB
- 57 cm x 43 cm x 22 cm
- 2-year warranty
- Height (Rack Units)
- 5U
- Rack Size
- 19"
- UPS Technology
- On-line
- Input Voltage
- AC 220/230/240 V
- Input Voltage Range
- AC 176 - 280 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 40 - 70 Hz
- Input Connectors
- Hardwire
- Power Output Connectors Details
- Output Voltage
- AC 230 V 50/60 Hz
- Power Capacity
- 4 kW / 5000 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Circuit Protection
- Circuit breaker
- Quantity
- 20
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Capacity
- 9 Ah
- Run Time (Up To)
- 8 min at full load , 21.5 min at half load
- Recharge Time
- 3 hours
- Remote Management Interface
- USB
- 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off)
- Expansion Slots
- 1 (total) / 1 (free) x Liebert IntelliSlot
- Emergency power off, built-in maintenance bypass, internal bypass
- EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, IEC 62040-1-1, EN 61000-4-5, IEC 62040-2
- Software Included
- Liebert MultiLink, Liebert Nform
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Sound Emission
- 50 dBA
- 57 cm
- 43 cm
- 22 cm
- 60 kg
- Shipping Width
- 74.5 cm
- Shipping Depth
- 53 cm
- Shipping Height
- 51.6 cm
- Shipping Weight
- 71 kg
