With 600 images per second, LG 42PN450B Plasma TV offers the clearest and smoothest images, even during fast motion. Enjoy sheer perfection of color, contrast, and clarity with the all-powerful Triple XD Engine. LG's latest and most advanced Triple XD Engine brings the highest level of excellence in color, contrast, and clarity for the best picture quality and performance.
600HZ Max
With 600 images per second, LG Plasma TV offers the clearest and smoothest images, even during fast motion. -
Triple XD engine
Enjoy sheer perfection of color, contrast, and clarity with the all-powerful Triple XD Engine. LG's latest and most advanced Triple XD Engine brings the highest level of excellence in color, contrast, and clarity for the best picture quality and performance. -
Razor frame
Enjoy immersive viewing and optimal design with razor-thin plasma TV. -
Protective glass
Worried about scratches and damages on your TV screen? LG Plasma TVs are protected by a protective glass, making them the strongest and most durable flat-screen TVs. Reliable tests have been conducted that show just how scratch resistant and sturdy they are. Keep your television in mint condition for as long as you use it.
- LG 42PN450B 42" plasma TV - HD
- Product Type
- Plasma TV
- Diagonal Class
- 42"
- Resolution
- 1024 x 768
- Display Format
- 720p
- Input Video Formats
- 720p, 1080i, 1080p
- Frame Rate & Enhancement Technology
- 600Hz sub-field driving
- 24p Technology
- 24p Real Cinema
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 2 ports
- Digital TV Tuner
- DVB-C, DVB-T
- Speaker System
- 2 speakers
- Sound Effects
- Virtual Surround Mode
- Stereo Reception System
- MTS
- USB
- Included Accessories
- Remote control
- Energy Class
- Class B
- Power Consumption (On mode)
- 93 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 136 kWh
- 98.36 cm x 25 cm x 65.03 cm
- 19.6 kg
- Product Type
- Plasma TV
- Energy Class
- Class B
- 93 W
- 136 kWh
- Diagonal Class
- 42"
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 2 ports
- Timer Functions
- Sleep, wake
- Dimensions
- With stand
- 98.36 cm
- 25 cm
- 65.03 cm
- 19.6 kg
Display
- Resolution
- 1024 x 768
- Display Format
- 720p
- 24p Technology
- 24p Real Cinema
- Dynamic Contrast Ratio
- 3000000:1
- Widescreen Modes
- Zoom 14:9, Conventional 4:3, Zoom, 16:9, Full Wide, Just Scan, Original, Cinema Zoom
- 3D Noise Reduction, Eye Care, MPEG Noise Reduction, Picture Wizard II, Triple XD Engine
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Features
- Swivel
- Flat Panel Mount Interface
- 400 x 400 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
- MTS
- Secondary Audio Programme (SAP)
Digital TV Tuner
- Digital TV Tuner
- DVB-C, DVB-T
- HDTV Tuner
Video Features
- Teletext
- Teletext Memory
- 2000 pages
- Electronic Programme Guide
- Digital EPG
- Parental Channel Lock
Media Player
- Supported Video Formats
- DivX HD
- Supported Audio Formats
- MP3, PCM, AC3, AAC, E-AC3, DTS
- Supported Pictures Formats
- JPG, MPO
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Digital Audio Format
- Dolby Digital output, DTS digital output
- Surround Mode
- Sound Effects
- Audio Controls
- Sound mode
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Clear Voice II technology
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- Composite video / component video / audio input - rear , Digital audio output (optical) - rear , HDMI input - side , USB 2.0 - side , Audio line-in - rear , HDMI input - rear , SCART - rear
- RoHS
- Power Device
- Power supply
- 0.3 Watt
- Smart energy saving
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 98.36 cm x 5.7 cm x 59.56 cm x 18.4 kg , Panel with stand - 98.36 cm x 25 cm x 65.03 cm x 19.6 kg
