Lexmark Prevail Pro705 A4 Colour Multifunction Printer
Quicklinx: 65D7WS00 Mfr#: 90T7031
Marketing description is not available.
  • Wi-Fi N for Intense Productivity
    Wi-Fi N gives you the freedom of wireless with 3x the coverage and faster transfer speeds than the previous wireless technology(1). Take advantage of Wi-Fi Protected Set-up to simplify the wireless set-up process. An Ethernet port gives you even more options.
  • The Industry's Best Guarantee
    Focus on work and leave the worry to us, thanks to a 5-year guarantee plus lifetime priority phone support (2). When we say reliable, we mean business.
  • Increase Your Efficiency
    An included XL black cartridge and 3 individual colour cartridges helps save resources and lowers printing costs.
  • Efficiency Built In
    Spend more time managing success, and less time managing paper supply with 150-page input capacity and 50 page automatic document feeder. Save money and resources with automatic two-sided printing.
  • Scan and Import Business Cards
    This advanced technology allows you to easily scan and save information from business cards, such as name, address and phone number. Rather than entering the information manually, you can scan up to 8 cards at a time and synch it with your address book software(3). That's real time saved.
Lexmark Prevail Pro705 - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Lexmark Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
10000 impressions
Max Copying Speed
Up to 25 ppm (mono) / up to 21 ppm (colour)
Max Printing Speed
Up to 33 ppm (mono) / up to 30 ppm (colour)
Max Printing Resolution
Up to 2400 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 4800 dpi
Display
2.4"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
216 x 432 mm (max)
Media Type
Transparencies, envelopes, plain paper, cards, iron-on transfers, photo paper, banner
Standard Media Capacity
150 sheets
Output Trays Capacity
50 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
46.5 cm x 39.2 cm x 25 cm
9.3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
5-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
10000 impressions
Display Diagonal Size
2.4"
Standard Memory
64 MB 64 MB
Supported Flash Memory
Memory Stick, SD Memory Card, MultiMediaCard, xD-Picture Card, Memory Stick PRO
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Scanning
Scan Element
CIS
Optical Resolution
1200 x 4800 dpi
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Supported Media Type
Borderless Photo Sizes
100 x 150 mm
150 sheets
50 sheets
Input tray - 150 sheets , Output tray - 50 sheets , ADF - 50 sheets
Speed Details
Printing: up to 33 ppm - B/W draft , Printing: up to 30 ppm - colour draft , Printing: up to 16 ppm - B/W normal , Printing: up to 10 ppm - colour normal , Copying: up to 25 ppm - B/W draft , Copying: up to 21 ppm - colour draft , Copying: up to 15 ppm - B/W normal , Copying: up to 8 ppm - colour normal
1 x USB 2.0 , 1 x USB host , 1 x LAN
Operating System Support
MS Windows XP, MS Windows 2000 SP4 or later, MS Windows XP Professional x64 Edition, MS Windows 7, Apple Mac OS X 10.3.9, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.4.4 - 10.5.x
Direct Printing Specifications
PictBridge
FCC Class B certified, CSA, TUV GS, VCCI Class B ITE, CCIB, SEMKO, IEC 60950, UL 60950 Third Edition, CB, C-Tick Class B, ICES Class B, CCC Class B, BSMI Class B, PSE Mark, IEC 60825-1, cULus
ENERGY STAR Certified
Limited warranty - 5 years , Limited warranty - replacement - 1 year
46.5 cm
39.2 cm
25 cm
9.3 kg
Shipping Width
54.2 cm
Shipping Depth
33 cm
Shipping Height
48.6 cm
Shipping Weight
12.1 kg
Sound Emission
52 dBA (operating)
