Highlights
- Leverages SuperSpeed USB 3.0 technology for high-speed file transfers, with USB interface speed up to 500MB/s
- Ultimate high-speed performance to accelerate digital workflow
- Maximizes speed and bandwidth of USB 3.0 computers, and the latest UDMA CompactFlash® (including UDMA 7), SDXC™, and SD UHS-I (SD 3.0) card formats
- Enables concurrent and card-to-card file transfers
- Pop-up design protects card slots when not in use
- Five-year limited warranty
SuperSpeed USB 3.0 Reader for Professional Photographers and Videographers
The Lexar® Professional USB 3.0 Dual-Slot Reader is a professional-level, portable USB reader that provides maximum high-speed file transfer, with a blazing-fast USB interface speed up to 500MB/s. This lets you leverage the performance capabilities of the latest UDMA CompactFlash® (CF) (including UDMA 7 CF 6.0), SDXC™*, and SD UHS-I (SD 3.0) memory cards.
Save Time and Significantly Improve Workflow
Accelerate Digital Workflow with High-Speed File Transfer. The Lexar Professional USB 3.0 Dual-Slot Reader leverages SuperSpeed USB 3.0 technology to deliver blazing-fast transfer speeds from card to computer, with a USB interface speed that reads up to 5 times faster than USB 2.0. An excellent choice for photo and video professionals looking to significantly accelerate workflow, the reader allows you to maximize the speed and bandwidth of next-generation USB 3.0 desktop and laptop computers, as well as the high-speed performance of the latest UDMA CF (including UDMA 7), SDXC, and SD UHS-I memory cards.
View a demonstration of the Lexar Professional USB 3.0 Dual-Slot Reader
Concurrent Transfers and Innovative Features for Ultimate Convenience. Created with convenience in mind, the Lexar Professional USB 3.0 Dual-Slot Reader has the ability to read both SD and CF cards simultaneously, and allows for easy file transfer from one card to another -- further enhancing the reader's versatility. And its LED activity light lets you know when transfer is complete. The reader also boasts an innovative, pop-up mechanism that protects the card slots by allowing you to close the reader when not in use. And with a compact, portable design, you can take it on the go, and its smooth contours help it easily slip in and out of your photo bag or briefcase.
Exceptional Performance, Quality, Compatibility, and Reliability. All Lexar memory card, card reader, and USB flash drive product designs undergo extensive testing in the Lexar Quality Labs, facilities with more than 800 digital devices, to ensure performance, quality, compatibility, and reliability. This provides customers with a high level of confidence when using Lexar products to capture, manage, move, and store the memories that matter.
Lexar offers a comprehensive line of innovative, award-winning memory products in several categories, including memory cards, card readers, and USB flash drives. With so many options, it's easy to find the right Lexar solution to fit your needs.
Lexar. When Memory Matters.™
Results may vary based on system configuration and card speed.
*Not supported on all operating system platforms.
- Lexar Professional USB 3.0 Dual-Slot Reader - card reader - USB 3.0
- Product Type
- Card reader - external
- Supported Memory Cards
- SD Memory Card, CompactFlash Card, SDHC Memory Card, SDXC Memory Card
- Host Interface
- USB 3.0
- Status indicator
- 5-year warranty
- Product Type
- Host Interface
- USB 3.0
- Status indicator
Memory Card
- Capacity
- (max)
- OS Required
- Apple MacOS X 10.0 or later, Microsoft Windows Vista / XP / 7
- Included Accessories
- USB cable
- Limited warranty - 5 years
