Lexar Professional - Flash memory card - 64 GB - Class 10 - 400x - SDXC UHS-I
Quicklinx: 81LQWS00 Mfr#: LSD64GCTBEU400
Impressive, professional-level speed and capacity for capturing high-quality images and HD video.
The premium Lexar® Professional 400x SDXC™ UHS-I card leverages UHS-I technology to deliver professional-level, high-speed performance and reliability, with 400x (60MB/s) minimum guaranteed read transfer speed.(1) This extended-capacity card is an excellent choice for sustained, rapid-fire shooting and capturing extended lengths of 1080p HD video with your SDXC-compatible camera.
Improve Capture, Capacity, and Workflow
Impressive High-Speed Performance to Accelerate Workflow. Designed for professional photographers and videographers, as well as advanced photo and video enthusiasts, the high-speed, Class 10 Lexar Professional 400x SDXC UHS-I card provides impressive blazing-fast performance. This means that whether you're interested in sustained, rapid-fire shooting or capturing 1080p HD video, this card gives you the power to get the job done. What's more, its high-capacity options allow you to store more high-quality images and 1080p HD video. And when using a USB 3.0 card reader, you'll speed through post-production with blazing-fast card-to-computer file transfer, allowing you to get back behind the camera faster.
Includes Valuable Downloadable Software. The Lexar Professional 400x SDXC UHS-I card includes the latest version of award-winning Lexar Image Rescue® software. Image Rescue 4 provides reliable recovery of most photo and video files, even if they've been erased or the card has been corrupted.(2) The software is available for free download with purchase of the card.
Outstanding Performance, Reliability, and Compatibility. The Lexar team works with major camera manufacturers to ensure all Lexar memory cards are compatible with their digital cameras--from the simplest to the most complex. To further ensure compatibility and performance, all Lexar memory cards are tested in the Lexar Quality Labs, facilities with more than 800 digital cameras and memory card devices. The Professional 400x SDHC UHS-I card provides outstanding performance, reliability, and compatibility, and also comes with a limited lifetime warranty and free dedicated professional technical support.
Highlights
Leverages UHS-I technology for blazing-fast performance, with 400x (60MB/s) minimum guaranteed read transfer speed(1)
Excellent for capturing high-quality images and 1080p HD video with any SDXC-compatible camera
High-speed, Class 10 card addresses the workflow needs of professional photographers and videographers
Includes downloadable Image Rescue® 4 software to recover lost or deleted photo and video files(2)
Free, dedicated professional technical support
(1)Minimum 60MB/s read transfer, write speeds lower. Speeds based on a TestMetrix certified tester. Actual sustained speed may vary depending on host device. x=150KB/sec.
(2)Image or other data recovery is not 100% guaranteed.
  • Impressive high-speed performance to accelerate workflow
    Designed for professional photographers and videographers, as well as advanced photo and video enthusiasts, the high-speed Lexar Professional SDXC UHS-I card provides impressive blazing-fast performance. This means that whether you're interested in sustained, rapid-fire shooting or capturing extended lengths of 1080p HD video, this card gives you the power to get the job done. What's more, its extended capacity allows you to store even more high-quality images and extended lengths of 1080p HD video.
  • Outstanding performance, reliability, and compatibility
    The Lexar team works with major camera manufacturers to ensure all Lexar memory cards are compatible with their digital cameras - from the simplest to the most complex. To further ensure compatibility and performance, all Lexar memory cards are tested in the Lexar quality labs, facilities with more digital cameras and memory card devices. The Professional SDXC UHS-I card provides outstanding performance, reliability, and compatibility.
Lexar Professional - flash memory card - 64 GB - SDXC UHS-I
Flash memory card
SDXC UHS-I Memory Card
Storage Capacity
64 GB
Speed Rating
Class 10 - 400x
Limited lifetime warranty (Germany - 10 years)
Flash memory card
Storage Capacity
64 GB
Speed Rating
400x
Speed Class
Class 10
Write Rate
Up to 60 MB/s
Limited warranty - lifetime , Germany: limited warranty - 10 years
