Print, copy and scan-functionality packed into a compact design makes the Kyocera FS-1220MFP a reliable and affordable companion for desktop users and home offices. This multifunctional printer prints 20 ppm in B/W and scans up to 21 ipm in B/W and color. Kyocera's long life technology and toner yields of 1600 pages keep costs down and your carbon footprint low.
- Kyocera FS-1220MFP - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 10000 pages
- Recommended Monthly Volume
- 1500 pages
- Max Copying Speed
- Up to 20 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 20 ppm
- Max Printing Resolution
- Up to 1800 x 600 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0
- Power
- AC 230 V (50/60Hz)
- 39 cm x 33.3 cm x 31.7 cm
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - monochrome
- 10000 pages
- 1500 pages
- Interface
- USB 2.0
- Standard Memory
- 64 MB 64 MB
Copying
- Max Copying Speed
- Up to 20 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy
Printing
- Up to 20 ppm
- First Print Out Time B/W
- 8.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 70 x 148 mm
- 250 sheets
- 100 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - B/W , Scanning: up to 18 spm (A4) - B/W , Scanning: up to 6 spm (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5 or later, Windows 8
- Voltage Required
- 316 Watt
- Power Consumption Standby
- 6 Watt
- Power Consumption Sleep
- 3 Watt
- Warm-Up Time
- 20 sec
- First Copy Out Time B/W
- 12 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages , 1 x drum - up to 100000 pages
- TUV GS
- ENERGY STAR Certified
- 39 cm
- 33.3 cm
- 31.7 cm
- Sound Emission
- 28 dBA (idle) / 50 dBA (operating)
