- Kyocera ECOSYS P6230cdn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 28.3 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - colour - A4 (210 x 297 mm) , Up to 15 ppm - duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- ARM Cortex-A9 1.2 GHz
- RAM Installed (Max)
- 1 GB (1 GB)
- Card Reader
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, XPS, PRESCRIBE IIc, PDF Direct
- Media Type
- Plain paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology
- 39 cm x 53.2 cm x 40.95 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6 sec
- First Print Out Time Colour
- 7 sec
- Colour Management Features
- Mopria
- Printer Features
- Media Handling
- Processor
RAM
- 1 GB / 1 GB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 2100 sheets
- Output Trays Capacity
- 250 sheets
- Networking
- Print server
- Remote Management Protocol
- SNMP 3
- SSL, IPsec
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 3500 pages , 1 x toner cartridge (cyan) - up to 2500 pages , 1 x toner cartridge (magenta) - up to 2500 pages , 1 x toner cartridge (yellow) - up to 2500 pages
- TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO 9296
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 466 Watt
- Power Consumption Stand by
- 65 Watt
- Power Consumption Sleep
- 0.6 Watt
Environmental Standards
- ENERGY STAR
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 49.5 dBA
- 39 cm
- 53.2 cm
- 40.95 cm
- 28.3 kg
Kyocera TK-5270K Black Toner | In Stock | £93.27 |
Kyocera TK-5270C Cyan Toner | In Stock | £115.30 |
Kyocera TK-5270M Magenta Toner | In Stock | £111.59 |
Kyocera TK-5270Y Yellow Toner | In Stock | £113.99 |
Kyocera Black toner Cartridge for P6230CDN | In Stock | £89.02 |
