Kingston USB microSD/SDHC Reader
Quicklinx: 7JRTWS00 Mfr#: FCR-MRG2
An essential for your mobile lifestyle.
This reader gives you an ultra-portable way to move photos, video clips,music and other files from your mobile phone to PC or PC to mobile phone. The reader is designed with a USB connector and a memory expansion slot that accepts a microSD/microSDHC/microSDXC card. Combine it with a microSD/microSDHC/microSDXC card and you've got the best mobile gear for your phone. This mobile-ready reader eliminates the need to carry additional USB transfer cables and the typical wait associated with slow Bluetooth® file transfers between phones and PCs. It also replaces your SD card adapter, since the microSD card fits directly into the reader. When in use, the microSD Card Reader appears as a drive letter (i.e. E:\) and data transfer is as simple as drag and drop. Use the reader with a microSD/microSDHC/microSDXC card to get the storage capacity for a variety of helpful transfers, or acquire content to side load to your phone, including:
  • Backing up your friends', relatives' or business contact information when you change phones
  • Moving the digital music library stored on your PC for use on your phone
  • Transferring a video captured on your camera phone to upload to the web without using additional network minutes
  • Downloading new mobile applications on your PC for use on your phone without using network time.
The reader is backed by a two-year warranty and Kingston's legendary service and support. It has an included keychain, so you can hang it from your phone for the convenient solution you need to complement your mobile lifestyle.
Store your entire mobile life -- photos, songs, text messages, video clips, personal information -- on a microSD/microSDHC/microSDXC card, then work with it across device platforms seamlessly with the microSD Card Reader.
Features / Benefits
Versatile -- works with microSD/microSDHC/microSDXC cards
Compliant -- with USB 2.0, SD Card Association specification
Portable -- easily fits in your pocket to take it with you
Easy -- plug-and-play into any USB 3.0 or 2.0 port
Guaranteed -- two-year warranty
  • Versatile compatibility
    Designed to work seamlessly with Mac, PC, and Unix systems, this USB microSD Reader offers a broad compatibility range, ensuring users can transfer data across different platforms without hassle.
  • Convenient portability
    With its external enclosure and a compact design that includes a keychain, this card reader is built for users on the go. Attach it to your keys for easy access whenever you need to manage your microSD and microSDHC cards.
  • Effortless usability
    Thanks to its compliance with Plug-and-Play standards, this device ensures a user-friendly experience that requires no additional software installation, making it ready to use right out of the box.
Kingston USB microSD Reader - card reader - USB 2.0
Card reader - external
Supported Memory Cards
microSD, microSDHC
Host Interface
USB 2.0
microSD, microSDHC
Host Interface
USB 2.0
24.9 mm
12.1 mm
2.6 mm
Memory Card
(max)
Required Ports
1 x 4 pin USB Type A
Microsoft Windows 2000 SP4, Microsoft Windows XP SP1 or later, Apple MacOS X 10.3.x or later, Microsoft Windows Vista, Linux 2.6 or later
Keychain
Plug and Play
