Kingston Media Reader - 19-in-1 Card Reader - Hi-Speed USB
Quicklinx: 5K9TWS00 Mfr#: FCR-HS219/1
Nothing goes better with digital media than an external reader for your desktop or laptop at home or on the road. Kingston's Media Reader opens a direct gateway between your digital media and a USB port by simply using expandable storage cards to move photos, music, data and more between devices and eliminating the need to carry cables to connect multiple devices.
  • Dimensions -- 3.61" x 2.71 x 0.79" (91.72mm x 68.82mm x 20.06mm)
  • Speed Rating* -- USB 2.0, up to 480 Mbps data transfer speed
  • Operating Temperature -- 32° to 140° F / 0° to 60° C
  • Storage Temperature -- -4° to 185° F / -20° to- 85° C
  • Weight -- 0.1585 lbs (71g)
  • Operating System Compatibility -- Windows® 7, Windows Vista®Windows Vista (SP1, SP2), Windows XP (SP1, SP2, SP3), Windows 2000 (SP4), Mac OS (v. 10.3.x +)
  • Versatile compatibility
    Designed to work seamlessly with both Mac and PC, this media reader offers a flexible solution for users across different platforms.
  • Extensive media support
    With a 19 in 1 card reader capability, it supports a wide range of memory cards including CompactFlash, Memory Stick variants, MultiMediaCard family, and SD formats, making it a comprehensive tool for photographers, videographers, and digital enthusiasts.
  • Easy connectivity
    Featuring a USB 2.0 interface, this external card reader ensures high-speed data transfer between your media cards and computer without the need for additional power sources.
  • Plug-and-Play convenience
    Compliant with Plug-and-Play standards, this device simplifies setup with no software installation required for Windows Vista certified computers, offering immediate usability right out of the box.
Kingston Media Reader - card reader - USB 2.0
Card reader - external - 19 in 1
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, miniSD, RS-MMC, MultiMediaCardmobile, microSD, MultiMediaCardplus, MultiMediaCardmicro, SDHC Memory Card, miniSDHC, Memory Stick Micro (M2), microSDHC
Host Interface
USB 2.0
Microsoft Certification
Certified for Windows Vista
Host Interface
USB 2.0
91.7 mm
68.8 mm
20.1 mm
71 g
Memory Card
(max)
Required Ports
1 x 4 pin USB Type A
Microsoft Windows 2000 SP3 or later, Microsoft Windows XP SP1 or later, Apple MacOS X 10.x or later, Microsoft Windows Vista
USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Plug and Play
