Kingston KVR HyperX Cooling Fan
Quicklinx: 64HSWS00 Mfr#: KHX-FAN
Designed with the gamer and PC enthusiast in mind, its dual 60mm fans optimize airflow around the modules to help memory run at peak performance for longer periods of time. The fan is made of anodized aluminum in the same familiar blue color as the HyperX heat spreaders. When turned on, the fan blades are illuminated by eight small blue LEDs.
  • Efficient cooling
    With an airflow of 15 cfm and a rotation speed of 3000 rpm, this memory fan unit ensures your PC components stay cool under pressure, enhancing performance and longevity.
  • Sleek design
    The anodized aluminum body paired with eight blue LEDs provides a sleek, modern look to your PC setup, combining functionality with style.
  • Customizable control
    Equipped with manual fan speed control, this unit allows for personalized cooling levels, ensuring optimal performance tailored to your needs.
HyperX Fan - memory fan unit
Memory fan unit
Blue
Fans Qty
Dual
Fan Diameter
60 mm
Rotation Speed
3000 rpm
Air Flow
15 cfm
Power Connector
3-pin plug
Blue LED x8
Product Material
Anodised aluminium
14.4 cm x 7 cm x 5.5 cm
Manual fan speed control
Memory fan unit
Product Material
Anodised aluminium
14.4 cm
7 cm
5.5 cm
Blue
Heatsink & Fan
Fans Qty
2
Fan Diameter
60 mm
Rotation Speed
3000 rpm
Air Flow
15 cfm
Power Connector
3-pin plug
Blue LED x8
Sound Emission
28 dBA
