Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for the following systems:
HP Compaq ProLiant BL20p G4 Server Blade;
HP Compaq ProLiant BL460c Server Blade;
HP Compaq ProLiant BL480c Server Blade;
HP Compaq ProLiant DL140 G3;
HP Compaq ProLiant DL360 G5;
HP Compaq ProLiant DL380 G5;
HP Compaq ProLiant ML150 G3;
HP Compaq ProLiant ML350 G5;
HP Compaq ProLiant ML370 G5;
HP Compaq Workstation xw6400;
HP Compaq Workstation xw8400.
- Kingston - DDR2 - kit - 8 GB: 2 x 4 GB - FB-DIMM 240-pin - 667 MHz / PC2-5300 - Fully Buffered
- Product Type
- Memory kit
- Capacity
- 8 GB: 2 x 4 GB
- Memory Type
- DDR2 SDRAM - FB-DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 667 MHz (PC2-5300)
- Fully Buffered
- OEM Manufacturer Equivalent Part Number
- HP 397415-B21
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Designed For
- HP Workstation xw6400, xw6600, xw8400, xw8600; HPE ProLiant BL20p G4, BL460c, BL480c, BL680c G5, DL140 G3, DL160 G5, DL180, DL360 G5, DL380 G5, DL580 G5, ML150 G3, ML350 G5, ML370 G5, xw460c; StorageWorks All-in-One Storage System 400r 1.2TB, 400r 1TB, 400r 2TB
- Capacity
- 8 GB: 2 x 4 GB
- Upgrade Type
- System specific
- HP 397415-B21
- DRAM memory kit
- Technology
- DDR2 SDRAM
- Form Factor
- FB-DIMM 240-pin
- Speed
- ECC
- Fully Buffered
- Designed For
- HP Workstation xw6400, xw6600, xw8400, xw8600 , HPE ProLiant BL20p G4, BL460c, BL480c, BL680c G5, DL140 G3, DL160 G5, DL180, DL360 G5, DL360 G5 Base, DL360 G5 Entry, DL360 G5 High Efficiency, DL360 G5 Performance, DL380 G5, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Efficiency, DL380 G5 High Performance, DL580 G5, DL580 G5 Base, DL580 G5 High Performance, ML150 G3, ML350 G5, ML350 G5 Base, ML350 G5 Entry, ML370 G5, ML370 G5 Base, ML370 G5 Entry, ML370 G5 High Performance, ML370 G5 Performance, xw460c Blade Workstation , HPE StorageWorks All-in-One Storage System 400r 1.2TB SAS Model, 400r 1TB SATA Model, 400r 2TB SATA Model
