DataTraveler HyperX Predator
The most powerful HyperX USB Flash drive combines extreme speed with high capacity.
Kingston's DataTraveler® HyperX® Predator USB Flash drive offers the fastest speeds from Kingston® and the highest capacities available in the world. Speeds up to 240MB/s read and 160MB/s write (in USB 3.0) mean users can quickly access, edit and transfer their files and applications directly from the drive with no performance lag. 1TB Capacity allow users to store their entire digital world on the DT HyperX Predator.
This prestigious drive is compliant with next-generation USB 3.0 specifications to take advantage of USB 3.0 ports in newer notebooks and desktops, and it includes a USB 3.0 dongle. It's also backwards compatible with USB 2.0 systems to maximize current investments.DT HyperX Predator offers superior quality in a high-end design. Its zinc alloy metal casing makes it shock-resistant; all drives must pass extensive durability and shock testing. It also features a custom Kingston key ring and HyperX Valet Keychain for added value.
For added peace of mind, this drive is backed by a five-year warranty, free technical support and the legendary reliability that makes Kingston the world's independent memory leader.
Dramatic speeds - 240MB/s read and 160MB/s write (in USB 3.0)
Monstrous 1TB capacity
USB 3.0 functionality, backwards compatible with USB 2.0
Exclusive metal casing with custom key ring and HyperX Valet Keychain
Supports Windows® 8, Windows® 7, Vista®, XP & Mac
Speed
USB 3.0: 240MB/s read and 160MB/s write
USB 2.0: 30MB/s read and 30MB/s write
Robust design
Crafted with an aluminum body and equipped with a key ring loop, this USB flash drive is designed for durability and convenience. Its shockproof construction ensures your data stays safe even in the face of accidental drops or impacts. -
High-speed performance
Experience swift data transfer with read rates of up to 240 MB/s and write rates of up to 160 MB/s. Whether you're moving large files, backing up your data, or loading games, it delivers efficient performance. -
Wide compatibility
Designed to work seamlessly with both Mac and PC, this USB flash drive offers versatile compatibility. Its USB 3.0 interface ensures fast data transfer rates and is backward compatible with USB 2.0 ports.
- Kingston DataTraveler HyperX Predator - USB flash drive - 1 TB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 1 TB
- OS Required
- Linux 2.6.x or later, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Apple MacOS X 10.6.x, Microsoft Windows 7 SP1, Windows 8
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 1 TB
- Read Rate
- Up to 240 MB/s
- Write Rate
- Up to 160 MB/s
- Interface Type
- USB 3.0
- Shockproof, metal body, key ring loop
- Included Accessories
- HyperX Valet key chain
- OS Required
- Limited warranty - 5 years
- 88.5 mm
- 26.9 mm
- 21 mm
- 0 °C
- 60 °C
