Kingston's HyperX SSD combines the SandForce controller technology with premium NAND flash, reducing load times while increasing performance and endurance. It provides high-speed SATA Rev 3.0 transfer speeds for larger bandwidth, which power users require for advanced gaming, multitasking and multimedia computing power. Kingston's HyperX SSD lets users load games and applications faster, increase frames per second (FPS) and quickly transfer and edit large media files. It's cool, silent and requires less power and no additional cooling requirements.
When configuring the HyperX SSD partition, the user can choose between having the maximum available capacity for data storage or giving up a little space to increase performance and endurance. This additional space is called over provisioning on an SSD. The amount of performance and endurance increase depends upon the type of data being stored on the HyperX SSD. The more data that is MPEG, JPG, ZIP or ARC file types, the greater the benefit for this increased over provisioning.
HyperX SSD uses an advanced wear leveling technology that distributes writes evenly across all the flash blocks in the SSD to maximize overall drive endurance. Additionally, wear leveling ensures that the individual flash memory blocks are consumed at a very balanced rate, not to exceed a 2-percent difference between the most often written blocks and least written. This enables the HyperX SSD to provide the longest possible life for the user while maintaining optimal performance.
Enhanced durability
Featuring shock-resistant technology and built-in wear leveling, the HyperX 3K Upgrade Bundle Kit is designed to withstand the rigors of daily use, ensuring a longer lifespan and consistent performance. -
High-speed performance
With an internal data rate of 555 MB/s for reading and 510 MB/s for writing, coupled with a maximum 4KB random write of 74,000 IOPS, this solid state drive delivers fast and reliable performance for demanding applications and multitasking. -
Efficient power consumption
The drive operates efficiently, consuming only 2.11 W in active mode and 0.455 W in idle mode, making it an energy-efficient choice for users looking to enhance their system's performance without significantly increasing power consumption.
- HyperX 3K Upgrade Bundle Kit - SSD - 90 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 90 GB
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- 2.5" x 1/8H (in 3.5" carrier)
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Shock resistant, built-in Wear Advanced Levelling, TRIM support, SandForce Driven, Garbage Collection technology, SandForce DuraClass, S.M.A.R.T.
- Enclosure Colour
- Black, aluminium
- 70 mm x 100 mm x 9.5 mm
- 97 g
- 3-year warranty
- Capacity
- 90 GB
- Form Factor
- 2.5" x 1/8H
- Interface
- SATA 6Gb/s
- 70 mm
- 100 mm
- 9.5 mm
- 97 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 555 MBps (read) / 510 MBps (write)
- 4KB Random Read
- 20000 IOPS
- 4KB Random Write
- 50000 IOPS
- Maximum 4KB Random Write
- 74000 IOPS
Reliability
- MTBF
- 1,000,000 hour(s)
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" x 1/8H or 3.5" (with included bay adapter)
- Power Consumption
- 2.11 Watt (active) , 0.455 Watt (idle)
- Software Included
- Drivers & Utilities
- Included Accessories
- 3.5-inch bay adapter, screwdriver, 2.5" USB enclosure
- Cables Included
- 1 x USB cable - USB Type A to mini-B - external , 1 x Serial ATA cable - internal
- Mounting Kit
- Included
- Enclosure Material
- Aluminium
- Enclosure Colour
- Black, aluminium
- Limited warranty - 3 years , Technical support
- 0 °C
- 70 °C
