All Kingston® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
- Kingston - DDR2 - kit - 8 GB: 2 x 4 GB - FB-DIMM 240-pin - 667 MHz / PC2-5300 - Fully Buffered
- Product Type
- Memory kit
- Capacity
- 8 GB: 2 x 4 GB
- Memory Type
- DDR2 SDRAM - FB-DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 667 MHz (PC2-5300)
- Fully Buffered
- OEM Manufacturer Equivalent Part Number
- IBM 43R1710 (x2), IBM 43R1773 (x2)
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Capacity
- 8 GB: 2 x 4 GB
- Upgrade Type
- System specific
- DRAM memory kit
- Technology
- DDR2 SDRAM
- Form Factor
- FB-DIMM 240-pin
- Speed
- ECC
- Fully Buffered
- Compatible Slots
- 2 x memory - FB-DIMM 240-pin
