Kingston 8GB Dual Rank Kit
Quicklinx: 3YCZWS00 Mfr#: KTH-MLG4/8G
Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for the following systems:
HP Compaq ProLiant BL20p G3;
HP Compaq ProLiant DL580 G3;
HP Compaq ProLiant ML570 G3;
HP Compaq ProLiant DL360 G4p;
HP Compaq ProLiant DL380 G4;
HP Compaq ProLiant ML350 G4p.
Kingston - DDR2 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 400 MHz / PC2-3200 - registered
Memory kit
8 GB: 2 x 4 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
400 MHz (PC2-3200)
Dual rank, registered
Voltage
1.8 V
HP 404122-B21
Limited lifetime warranty (Germany, Austria and France - 10 years)
HPE ProLiant DL580 G3, DL580 G3 High Performance, DL580 G4, DL580 G4 High Performance, ML570 G3, ML570 G3 High Performance, ML570 G4, ML570 G4 High Performance
8 GB: 2 x 4 GB
Upgrade Type
System specific
HP 404122-B21
DRAM memory kit
DDR2 SDRAM
DIMM 240-pin
Speed
400 MHz (PC2-3200)
ECC
Voltage
1.8 V
Compatible Slots
2 x memory - DIMM 240-pin
