Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
- Kingston - DDR2 - kit - 4 GB: 2 x 2 GB - DIMM 240-pin - 667 MHz / PC2-5300 - registered
- Product Type
- Memory kit
- Capacity
- 4 GB: 2 x 2 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 667 MHz (PC2-5300)
- Registered
- OEM Manufacturer Equivalent Part Number
- HP 408853-B21, HP EV283AA (x2)
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Designed For
- HP Workstation xw9400; HPE ProLiant BL465c, DL385 G2, DL585 G2
- Capacity
- 4 GB: 2 x 2 GB
- Upgrade Type
- System specific
- DRAM memory kit
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Registered
- Designed For
- HP Workstation xw9400 , HPE ProLiant BL465c, DL385 G2, DL585 G2
