Kingston 4GB 1333MHz Module
Quicklinx: 72C5WS00 Mfr#: KTL-TP3B/4G
Kingston 4GB 204-Pin DDR3 SO-DIMM Unbuffered DDR3 1333 (PC3 10600) System Specific Memory for Lenovo Model KTL-TP3B/4G
Kingston - DDR3 - module - 4 GB - SO-DIMM 204-pin - 1333 MHz / PC3-10600 - unbuffered
Memory module
4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Unbuffered
IBM 55Y3717
4 GB
Upgrade Type
System specific
IBM 55Y3717
DRAM memory module
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 204-pin
