Kingston 16GB Kit (Chipkill)
Quicklinx: 6DK1WS00 Mfr#: KTM2759K2/16G
All Kingston® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
Kingston - DDR2 - kit - 16 GB: 2 x 8 GB - DIMM 240-pin - 667 MHz / PC2-5300 - registered
Memory kit
16 GB: 2 x 8 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC Chipkill
Speed
667 MHz (PC2-5300)
Registered
IBM 43V7356, IBM 43V7355 (x2), IBM 40V6128
Limited lifetime warranty (Germany, Austria and France - 10 years)
Lenovo System x3850 M2 7141, 7233; x3950 M2 7141, 7233
16 GB: 2 x 8 GB
Upgrade Type
System specific
DRAM memory kit
DDR2 SDRAM
DIMM 240-pin
Speed
667 MHz (PC2-5300)
ECC Chipkill
Registered
Compatible Slots
2 x memory - DIMM 240-pin
Lenovo System x3850 M2 7141, 7233 , Lenovo System x3950 M2 7141, 7233
