Your basket is empty
Kingston 120GB SSDNow V300 SATA 6Gb/s 2.5" 7mm Solid State Drive
Quicklinx: 8F75WS00 Mfr#: SV300S37A/120G
Form Factor: 2.5"
Capacity: 120GB
Interface: Serial ATA-600
Type: Internal hard drive
Stock Status: Clearance
Select:
21 left in stock
£49.99 ex VAT
£59.98 inc VAT
Express delivery Order within the next 23 hours for delivery on Friday
Revive your computer
Get more life out of your computer and maximise your existing investment by replacing your old hard drive with a Kingston® SSDNow V300 solid-state drive. It's the most cost-efficient way to dramatically improve the responsiveness of your system -- and it's less disruptive than migrating your data to a new system.
SSDNow V300 features an LSI® SandForce® controller customised for Kingston and optimised for next-generation Flash memory to deliver the utmost in quality and reliability from two leading SSD brands. Because it's made with solid-state components and has no moving parts, it's shock-proof and withstands drops and bumps.
It's backed by a three-year warranty, free technical support and legendary Kingston reliability.
  • Cost-effective system upgrade
  • Makes your system more responsive
  • Maximises your computer investment
  • Faster -- improves speed of loading applications and system boot up
  • Reliable -- with no moving parts, solid-state drives are less likely to fail than standard hard drives
  • Economical -- design optimised to make migrating to an SSD more affordable
  • Form factor -- 2.5-inch drive available in 7.0mm with adapter to fit in 9.5mm systems
  • Silent -- cool and silent operation
  • Guaranteed -- three-year warranty, free technical support
  • Form factor 2.5
  • Interface SATA Rev. 3.0 (6Gb/s) - with backwards compatibility to SATA Rev. 2.0
  • Capacity 120GB
  • Sequential reads2 S ATA Rev. 3.0 up to: 450MB/s
  • Sequential writes2 S ATA Rev. 3.0 up to: 450MB/s
  • Maximum random 4k read/write
  • 120GB -- up to 85,000 / up to 55,000 IOPS
  • PCMARK® Vantage HDD Suite score 120GB: 49,000
  • Power consumption 0.640 W idle / 1.423 W read / 2.052 W write
  • Storage temperatures -40°C~85°C
  • Operating temperatures 0°C~70°C
  • Dimensions 69.8mm x 100.1mm x 7mm
  • Weight 86g
  • Vibration operating 2.17G peak (7-800Hz)
  • Vibration non-operating 20G peak (10-2000Hz)
  • Life expectancy 1 million hours MTBF
  • Warranty/support three-year warranty with free technical support
  • Total Bytes Written (TBW) 120GB:64TB
See It In Action
Kingston SSDNow V300 - solid state drive - 120 GB - SATA 6Gb/s
Solid state drive - internal
120 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant, SandForce Driven
69.8 mm x 100.1 mm x 7 mm
86 g
Microsoft Certification
Compatible with Windows 7
3 years warranty
120 GB
2.5"
SATA 6Gb/s
69.8 mm
100.1 mm
7 mm
86 g
Performance
SSD Endurance
64 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
450 MBps (read) / 450 MBps (write)
Maximum 4KB Random Write
55000 IOPS
Maximum 4KB Random Read
85000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
1.423 Watt (read) , 2.052 Watt (write) , 0.64 Watt (idle)
ISO 9001:2008, SGS
Limited warranty - 3 years , Technical support
70 °C
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Kingston 120GB SSDNow V300 SATA 6Gb/s 2.5 Bundle deal on Kingston 120GB SSDNow V300 SATA 6Gb/s 2.5" 7mm Solid State Drive
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.39 | in stock
£52.69
saving £2.70
Including:
£52.69
saving £2.70
8F75 StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £6.65
8F75 StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £11.76
8F75 StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm In Stock £16.45
8F75 StarTech.com 2.5in USB 3.0 SATA Hard Drive Enclosure w/ UASP for Slim 7mm SATA III SSD/HDD In Stock £15.43
Resources
The following resources are available for the Kingston 120GB SSDNow V300 SATA 6Gb/s 2.5" 7mm Solid State Drive
Form Factor: 2.5"
Capacity: 120GB
Brand: Kingston
Price Range Ex VAT: 0 - 50
