Engineered to be s small lock for laptops and other devices with no compromises, the MicroSaver 2.0 represents the next generation of laptop security with a cable that's stronger than the standard model. The MicroSaver 2.0 was developed using strict specifications and advanced technologies in a smaller, compact size.
Strong lock heads
The lock head is designed for even thin laptops and devices while still meeting Kensington's standards for tamper-resistance, reliability and durability. -
T-Bar locking technology
The rotating bar securely attaches to the internal wall of the device for a premium level of security. -
Ultra carbon steel cable
The thicker cable is stronger than a standard cable, made of woven carbon steel and covered by an anti-shearing sleeve for the high level of protection against cutting attempts. -
Pivot and rotate cable
Special hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
- Kensington MicroSaver 2.0 Keyed Ultra Laptop Lock - security cable
- Product Type
- Security cable
- Silver
- Product Material
- Carbon steel
- T- bar lock, pivot adjustment, cut-resistant, hidden pin, rotatable
- Product Type
- Security cable
- Product Material
- Carbon steel
- Silver
