Kensington Slimblade Trackball
Quicklinx: 6ND6WS00 Mfr#: K72327EU
Kensington TrackballWorks
idea: Your trackball, your rules.
Download Kensington TrackballWorks software to customise the functions of each of the buttons found on this Kensington trackball. The result is a more productive and truly personalized computing experience. Set your preferred functions or keyboard shortcuts for each trackball button or combination of buttons, adjust the pointer speed and acceleration and do so much more. Best of all, by allowing you to personalise your trackball experience, TrackballWorks makes your trackball work the way you do. TrackballWorks is compatible with the latest operating system versions including Windows 7, Windows Vista , Windows XP and Mac OS.
Kensington SlimBlade Trackball - trackball - USB - Ruby Red, metalic silver
Trackball
Wired - USB
Orientation
Right and left-handed
Europe
Movement Detection Technology
Laser / optical
Buttons Qty
4
Cable Length
1.5 m
1 x USB cable - integrated
Microsoft Windows 7 or later, Apple MacOS X 10.8 or later
Microsoft Certification
Compatible with Windows 7
3-year warranty
Trackball
Orientation
Europe
Input Device
Wired
USB
Laser / optical
Buttons Qty
4
Cable Length
1.5 m
1 x USB - 4 pin USB Type A
USB 2.0
Limited warranty - 3 years
