Kensington ClickSafe 3-in-1 Combination Lock (T-Bar, Nano & Wedge Anchors)
Quicklinx: G8PMWS00 Mfr#: K68105EU
Device Type: Laptop
Type: Security
Device Screen Size: [N/A]
Colour: Silver, Black
17 In Stock
£42.79 ex VAT
£51.34 inc VAT
The ClickSafe Universal Combination Laptop Lock fits any laptop security slot – standard T-bar, Nano or Wedge-Shaped – to lock down your laptop, regardless of laptop brand or generation. From Kensington, inventor and worldwide leader in laptop security locks.
  • One lock for any slot
    Fits standard T-bar, nano, or wedge-shaped laptop security slots, regardless of brand or generation.
  • ClickSafe locking technology
    Allows the lock head to be attached with one hand in a single click.
  • Carbon steel cable
    1.8m (6 ft.) cable with plastic sheath resists tampering, offers peace-of-mind, and delivers the same level of cut-resistance and theft-resistance as thicker cables.
  • Pivot and rotate cable
    A special hinge allows flexible movement.
  • Verified & tested
    Each Kensington lock is precision engineered to meet or exceed rigorous industry standards for strength, physical endurance, and mechanical resilience.
Kensington ClickSafe Universal Combination Laptop Lock - security cable lock
Security cable lock
Product Material
Carbon steel
3.76 cm x 1.42 cm x 3.25 cm
Length
1.8 m
230 g
Combination lock, T- bar lock, cut-resistant, pivoting lock head
Europe
Security cable lock
Product Material
Carbon steel
3.76 cm
1.42 cm
3.25 cm
Length
1.8 m
Diameter
5 mm
230 g
Europe
Limited warranty: - 2 years
Device Type: Laptop
Type: Security
Colour: Silver
Colour: Black
Brand: Kensington
