Reduce glare and harmful blue light, and improve clarity with Kensington's Anti-Glare and Blue Light Reduction Filter for 13.3" Laptops. This filter reduces harmful blue light by up to 43%, and features an antimicrobial coating (matte side only) that inhibits bacteria growth by up to 99% (tested to JIS Z 2801 : 2010E for Escherichia coli and Staphylococcus aureus). An innovative anti-glare coating (matte side only) reduces reflection and improves clarity. Seamless attachment makes installation and removal easy and mess-free.
Reduces glare and harmful blue light
Innovative anti-glare coating reduces reflection and improves clarity (matte side only). Filter eliminates blue light by up to 43%, easing eye strain and reducing the chances of interrupting sleep patterns. -
Antimicrobial coating (matte side only)
Inhibits bacteria growth by up to 99%. -
Seamless attachment
Makes installation and removal easy and mess-free. -
Touch and pen enabled
Allows you to use your device just as you would without a filter.
- Kensington - notebook screen protector - blue light filter and anti-glare
- Product Type
- Notebook screen protector - blue light filter and anti-glare
- Installation Type
- Removable
- Package Content
- Cleaning cloth
- Transparent
- Product Material
- PET
- 29.4 cm 16.6 cm
- 18 g
- Display Screen Size Compatibility
- 13.3" wide
- Anti-reflective, antimicrobial finish, 3H hard-coating, blue light cutting
- Product Type
- Product Material
- PET
- Package Content
- Cleaning cloth
- 29.4 cm
- 16.6 cm
- Thickness
- 0.44 mm
- 18 g
- Shipping Dimensions (WxDxH) / Weight
- 25 cm x 0.5 cm x 36 cm / 552 g
- 13.3" wide
- Transparent
Display Filter
- Installation Type
- Removable
- Aspect Ratio
- 16:9
- Limited warranty: - 2 years
