The Jabra Pro 9450 Flex wireless headset delivers up to 150 metres of range and connects to your mobile, deskphone or softphone. This versatile headset also features an extendable flex boom-arm that allows for perfect microphone adjustment, a noise-cancelling microphone, acoustic protection and wideband audio quality.
One headset for all phones
Take every call on the same headset. Connects to your desk phone, mobile and softphone - all at the same time. Manage multiple calls through an industry-first, user-friendly touch-screen or touchpad. Also comes with a SmartSetup wizard that guides you through the connection process. -
Outstanding sound quality
If you talk and listen for a living, clear conversations can make or break a deal. Get best-in-class noise-cancellation and acoustic protection. Your calls will sound great – even in the noisiest of offices. Noise Blackout : Ear cushions and microphone are specially designed to eliminate background noise. Digital Signal Processing and HD Voice make your calls more intelligible and lifelike. SafeTone technology automatically counters unexpected spikes in volume and protects your ears. -
True wireless freedom
Wireless DECT technology allows you to roam up to 150 metres away from your desk without dropping the call. Answer and end calls remotely while multitasking around the office. With up to 10 hours of battery life, you won't need to worry about running out of charge. -
DECT security compliant
Compliant with the latest security requirements of the DECT standard, designed to safeguard against eavesdropping. The Jabra-patented headset-to-base pairing process avoids risky pairing over the air to protect your conversations. -
10-Hour Battery Life
Multi-device connectivity technology lets you manage phone calls from several different devices such as deskphones, tablets, PCs and smartphones, with one single headset. You get greater flexibility and enhanced user experience.
- Jabra PRO 9450 Flex - headset
- Product Type
- Headset - DECT - wireless
- Recommended Use
- Phone, computer
- Localisation
- Hong Kong, Singapore, United Kingdom
- Headphones Form Factor
- Convertible - monaural
- Connectivity Technology
- Wireless
- Wireless Technology
- DECT
- Sound Output Mode
- Mono
- Audio Specifications
- Frequency Response 150 - 6800 Hz
- Microphone
- Boom
- Controls
- Mute, volume, tone, answer/end
- Product Type
- 28 g
- Recommended Use
- Phone, computer
- Max Operating Distance
- 150 m
- Localisation
Audio Output
- Wireless
- DECT
- Sound Output Mode
- Mono
- 150 - 6800 Hz
Microphone
- Boom
Remote Control
- Controls
Wireless Link
- Transmission Range
- 150 m
- Battery
- Headset battery rechargeable
- Included Qty
- 1
- Capacity
- 315 mAh
- Run Time (Up To)
- 10 hour(s)
- Standby Time
- 46 hours
