Jabra BIZ 2400 II Mono UC USB Headset
Quicklinx: BGHMWS00 Mfr#: 2496-829-309
Recommended Use: Portable electronics, Computer
Connectivity: Wired
Earcover : Monaural
£140.81 ex VAT
£168.97 inc VAT
The BIZ 2400 II offers outstanding sound at both ends of the call for a superior customer experience, a corded professional headset that delivers outstanding sound on both ends of the call. Up to 40% lighter than competing headsets and with a low pressure, super-soft leatherette headband, the Biz 2400 II allows the agent to focus on their customer conversation in unrivalled comfort.
Better conversation
The most important function of a contact centre headset is eliminating background noise from the busy environment and letting the customer hear your voice clearly. The ultra-noise-cancelling microphone provides the highest degree of background noise elimination in any of our headsets.
Jabra BIZ 2400 II USB UC Mono is a stereo headset that provides USB connectivity to all leading UC applications and softphones.
  • Better conversation
    The most important function of a contact centre headset is eliminating background noise from the busy environment and letting the customer hear your voice clearly. The Biz 2400 II has a superior noise-cancelling microphone that helps eliminate background noise to give a better customer experience.
  • Better sound
    If you're in a busy environment, you need great sound to hear the voice of your customer. Additionally, when you're concentrating on work, you want that hi-fi sound for music. The Jabra Biz 2400 II is great at both. HD Voice technology makes sure you clearly understand the other party The speakers reduce ambient noise, so you can focus on the call A specially designed "air shock" noise-cancelling mic filters out sharp breathing sounds and popping noises often heard in conversations.
  • Better design
    The Jabra Biz 2400 II is built to last in a high-performing contact centre, meaning fewer headset replacements and less downtime for you and your team and lower total cost of ownership. Reinforced cord is built to withstand the contact centre environment and is protected against office chair wheels, sharp objects and daily use The boom-arm can be rotated 360 degrees with zero risk of breaking. We call this FreeSpin .
  • Better comfort
    The Jabra Biz 2400 II has an extremely lightweight and unobtrusive design. This means less agent fatigue and more productive calls. 40% lighter than competing high-end headsets The adjustable headband and microphone boom arm let you find the perfect fit The control unit lets you change volume, mute your calls and more PeakStop technology removes sudden loud sounds or tones before they reach your ears: Any sound above 118 dB is filtered out. Super-soft leatherette head and ear cushioning.
  • Easy call management
    Jabra headsets with in-line call controller give end-users greater productivity and convenience, with large buttons and LED indicators for quick access. Pick up or end calls, control volume or simply mute the microphone. In addition, all buttons are user programmable.
  • Hi-fi Sound
    Immerse yourself in music with hi-fi sound. Listen to flawless music reproduction across the entire audible frequency range.
Jabra BIZ 2400 II USB Mono CC - headset
Headset - wired - USB
Recommended Use
Portable electronics, computer - communication
Headphones Form Factor
On-ear - convertible
Wired
Sound Output Mode
Mono
Audio Specifications
Frequency Response 60 - 1600 Hz
Max Input Power
20 mW
Microphone
Boom
Microphone Noise Cancelling
Controls
Volume, mute button, answer/end, programmable button
2.7 cm
13.9 cm
16.7 cm
Earpad Material
Leatherette, foam
Recommended Use
Protection
Breath-resistant
Audio Output
Wired
Sound Output Mode
Mono
Frequency Response
60 - 1600 Hz
Max Input Power
20 mW
Diaphragm
30 mm
In-Cord Volume Control
Adjustable Headband
PeakStop technology, FreeSpin technology
Microphone
Boom
Headset microphone
Noise Cancelling
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
Cable
Cable Length
2.3 m
Clothing clip, neckband, 2 earhooks
Cable Details
Headset cable - Kevlar reinforced - 2.3 m
G616
BGHM Jabra BIZ 2400 Earhook In Stock £17.00
BGHM Jabra BIZ 2400 Leatherette ear cushions, 10 unit PACK In Stock £24.86
Recommended Use: Computer
Connectivity: Wired
Earcover : Monaural
Brand: Jabra
