istorage 500GB diskGenie 128-bit 5400rpm 8MB USB 2.0 Encrypted HDD
Quicklinx: 7QQDWS00 Mfr#: IS-DG-128-500
The diskGenie from iStorage offers powerful hardware encryption in a compact, portable device with a totally unique difference. With an easy-to-use keypad design and software free setup, the iStorage diskGenie is only accessible using a PIN code similar to using an ATM.
Also featuring AES 256 bit real time hardware encryption, it protects the data on the drive keeping it safe even if the hard drive is removed from its enclosure. Quite simply, the iStorage diskGenie is the ultimate portable hard drive and secure storage system.
With no software to install, easy setup and real-time encryption, the diskGenie is the best way to protect your data, customers and your business.
Its low powered, compact, robust design features a 16-point omni-directional shock mounting system, protecting the drive from drops and knocks. It is perfect for safely transporting data between office and home as well as storing photos, music and video files.
The diskGenie also offers stress free deployment in corporate environments whilst adding secure additional capacity to your system. Allowing the enrollment of up to ten unique user IDs and one administrator, it is an unparalleled business collaboration tool.
  • Easy to use keypad design
    Unlock the drive with your own unique six- to sixteen-digit pin.
  • Real-time 256-bit AES hardware encryption
    Encrypts 100% of your data in real-time and keeps your data safe even if the hard drive is removed from the enclosure.
  • No software installation
    No software required to setup or operate - making it perfect for corporate deployments.
  • Administrator feature
    Allows enrollment of up to ten unique user ID's and one administrator, making it a useful business collaboration tool.
  • 100% of data on drive encrypted
    All data on the drive is encrypted in real-time - no speed degradation - data not accessible even if drive is removed.
  • Ultra-portable design
    Ideal to take between home and the office or on trips.
  • Low powered design
    Bus powered from standard USB port.
  • Plug and Play and compatible on any system
    No need to power down, just plug and go.
  • Secure storage
    Excellent for notebook owners, road warriors, government, health care, insurance companies, financial institutions, HR departments and executives with sensitive data.
iStorage diskGenie - hard drive - 500 GB - USB 2.0
Hard drive - external (portable)
500 GB
Hardware Encryption
USB 2.0
Data Transfer Rate
480 Mbps
Buffer Size
8 MB
Spindle Speed
5400 rpm
Built-in keypad, password authentication, Hardware Full Disk Encryption (FDE), 128-bit AES
Power Source
USB bus
8.5 cm x 12 cm x 1.9 cm
176 g
3-year warranty
500 GB
Hardware Encryption
USB 2.0
Buffer Size
8 MB
8.5 cm
12 cm
1.9 cm
176 g
Performance
Interface Transfer Rate
480 Mbps
Seek Time
12 ms (average)
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 2.0 - 4 pin USB Type A
Power Source
USB bus
Linux, Apple MacOS X 10.2 or later, Microsoft Windows 2000/XP/Vista/7
System Requirements Details
Pentium RAM 32 MB
Carrying case
1 x USB cable - integrated
Plug and Play, FCC, RoHS, WEEE
Limited warranty - parts and labour - 3 years
Shock Tolerance
300 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
