Iomega offers USB 3.0 adapter cards to insert in your desktop computer so you can experience native USB 3.0 transfer speeds up to 5 Gbits/s! This card is also backwards compatible with USB 2.0 devices. Connections to USB 2.0 devices will lead to USB 2.0 performance.
Enhanced compatibility
Designed to seamlessly integrate with PC systems, this USB adapter ensures a smooth connection interface for a wide range of applications. -
High-speed connectivity
Featuring USB 3.0 ports, the adapter offers rapid data transfer rates, making it ideal for efficient file transfers. -
Easy installation
With its plug-in card form factor and PCI Express interface, the adapter is designed for quick and straightforward installation, requiring minimal setup effort.
- Iomega - USB adapter - PCIe - USB 3.0 x 2
- USB adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express
- Ports
- USB 3.0 x 2
- Data Link Protocol
- USB 3.0
- USB 1.1, USB 2.0, USB 3.0
- System Requirements
- Microsoft Windows Vista / XP / 7
- 1-year warranty
- Designed For
- P/N: 34985, 35054
- USB adapter
- Form Factor
- Plug-in card
- PCI Express
- Ports
- USB 3.0 x 2
- Connectivity Technology
- Wired
- SuperSpeed USB 3.0
- 2 x USB 3.0
- Compatible Slots
- 1 x PCI Express
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 1 year
- Designed For
- P/N: 34985, 35054
