Future-proof your digital storage with the Iomega SSD Flash Drive! With write speeds up to twice as fast as 7200 RPM SATA hard drives, the Iomega SSD Flash Drive is the latest technology for computer users who demand the highest performance from their digital storage. All Iomega USB 3.0 drives are backward compatible to USB 2.0 using the same USB cable. This solid state drive has no moving parts to allow for fast application loading, top transfer speeds for HD video, graphics, and music, plus greater overall system responsiveness. It includes a fast SuperSpeed USB 3.0 interface and is USB powered. Cool to the touch and silent, it also requires less power to run so conserves your laptop battery. Plus, it's compact and super-rugged for mobile use. It includes Iomega Drop Guard Xtreme II that helps the drive survive drops up to 10 feet. 256-bit hardware encryption is built-in for your data security (PC only); Protection Suite software is included via download.
- Iomega SSD Flash External Drive - SSD - 256 GB - USB 3.0
- Solid state drive - external (portable)
- Capacity
- 256 GB
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- 1.8"
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Rugged, DropGuard Xtreme II, 256-bit AES
- Power Source
- USB bus
- Enclosure Colour
- Black
- 6.9 cm x 11 cm x 0.9 cm
- 109 g
- 3-year warranty with product registration
- Capacity
- 256 GB
- Form Factor
- 1.8"
- Interface
- USB 3.0
- 6.9 cm
- 11 cm
- 0.9 cm
- 109 g
Performance
- Interface Transfer Rate
- Internal Data Rate
- 191 MBps (read) / 130 MBps (write)
Reliability
- MTBF
- 1,200,000 hours
Expansion & Connectivity
- 1 x USB 3.0
- Compatible Bay
- 1.8"
- Power Source
- USB bus
- Software Included
- Iomega Protection Suite
- OS Required
- Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4 - 10.6
- System Requirements Details
- Windows XP/Vista/7 - RAM 256 MB
- Cables Included
- 1 x USB cable - external
- Enclosure Colour
- Black
- Limited warranty - 3 years
