Intel Wireless WIFI Link 7265
Quicklinx: C45CWS00 Mfr#: 7265.NGWWB.W
  • Bluetooth 4.0
  • IEEE 802.11n
The Intel® Dual Band Wireless-AC 7265 802.11ac, 2 x 2 Wi-Fi and Bluetooth adapter lets you move at the speed of life with 3x faster speed (up to 867 Mbps) than 802.11n Wi-Fi, more capacity for more devices, better performance at further distances, improved reliability for fewer dropped connections, and lower power consumption for longer battery life.
Intel Dual Band Wireless-AC 7265 - network adapter - M.2 Card
Network adapter
Plug-in card
Interface (Bus) Type
M.2 Card
3 cm x 0.24 cm x 2.2 cm
2.4 g
Bluetooth 4.0, Wi-Fi 5
Data Transfer Rate
867 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, Bluetooth 2.1, Bluetooth 3.0, Bluetooth 4.0, IEEE 802.11ac, IEEE 802.11w
Linux, Microsoft Windows 7, Windows 8
Microsoft Certification
Compatible with Windows 7
Network adapter
Plug-in card
M.2 Card
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Data Transfer Rate
867 Mbps
Frequency Band
2.4 GHz, 5 GHz
WMM support, WPS, WiDi, Wi-Fi Direct, Intel Smart Connect Technology, Wi-Fi Miracast ready
Encryption Algorithm
LEAP, 128-bit WEP, 64-bit WEP, TLS, PEAP, TTLS, TKIP, WPA, WPA2, AES-CCMP
UL, cUL, CB, IEC 60950-1, FIPS, FISMA
3 cm
0.24 cm
2.2 cm
2.4 g
80 °C
50 - 90% (non-condensing)
