IcyBox 5.25" Card Reader with Multiport Front Panel
Quicklinx: 7KJKWS00 Mfr#: IB-863
Makes the Computer More Sociable
Many peripherals can get in touch due to the multi-port front panel. 60 memory cards fit and can be read. Two USB 3.0 ports make super fast data transfer possible. That's the future standard for multimedia.
NOTE: For using the two USB 3.0 ports, two external USB 3.0 ports on the main board or two USB 3.0 ports on an USB 3.0 PCI-X extension card are required.
With the IB-863 the computer becomes a lot more functional with the options of 60 different memory cards can be used as well as the two USB 3.0 ports, making room for many peripherals to connect to the computer.
The two USB 3.0 ports can provide upto x10 transfer speeds of conventional USB 2.0, perfect for larger files like movies.
The IB-863 fits nicely into a standard 5.25" bay on your computer case, and provides excellent possibilities for USB memory cards, hubs, keyboards as well as the memory card slots, microphone and earphone ports there are 4 x USB 2.0 ports and eSATA which provides connectivity for a vast ammount of usage.
All Icy Box products are manuafactured with high quality components which is why Icy Box is a leading brand in the storage enclosure market, along with being able to provide a storage solution for almost any situation and data requirements, which is why you can be confident in choosing Icy Box for your storage needs.
Box Contains
  • 1x IB-863-B
  • 1x USB 3.0 bracket
  • 1x screw set
  • 1x manual
Spec
  • 5.25" Card Reader with multiport front panel
  • Fits into standard 5.25" Bay
  • 6 x Card Reader Slots
  • Support for 60 types of memory card
  • 4 x USB 2.0, 2 x USB 3.0, 1 x eSATA interface
  • 1 x Microphone + 1 x Earphone ports
ICY BOX IB-863-B - card reader - USB 2.0
Card reader - internal
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, xD-Picture Card, Memory Stick PRO Duo, RS-MMC, microSD, SDHC Memory Card, Memory Stick Micro (M2), SDXC Memory Card
Host Interface
USB 2.0
Required Bay
5.25" internal
Host Interface
USB 2.0
Required Bay
5.25" internal
148 mm
41 mm
74 mm
286 g
Memory Card
(max)
Additional Ports
1 x USB 3.0 , 2 x USB 2.0 , 3 x eSATA , 4 x microphone input , 5 x headphone output
