IBM Half High Multi-burner Optical Drive
Quicklinx: 7RM7WS00 Mfr#: 94Y6237
IBM Multi-Burner is one drive that now does it all. It reads and writes both DVDs and CDs. This high-capacity read/write removable storage solution is perfect for file sharing, backup, audio CD creation, software installations and DVD video playback.
Lenovo Multi-Burner Drive DVD±RW (±R DL) / DVD-RAM drive - Serial ATA - internal
DVD±RW (±R DL) / DVD-RAM drive - internal
Serial ATA
14.6 cm x 16.5 cm x 4.1 cm
0.7 kg
Optical Storage
DVD±RW (±R DL) / DVD-RAM - 5.25" x 1/2H
Read Speed
40x (CD) / 16x (DVD)
Write Speed
40x (CD) / 16x (DVD±R) / 8x (DVD±R DL)
CD / DVD Rewrite Speed
32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
Media Load Type
Tray
Manufacturer Selling Program
IBM Express Seller
1-year warranty
System x3100 M3; x3400 M2; x3400 M3; x3550 M2; x3550 M3; x3650 M2; x3650 M3; x3850 X5
Serial ATA
14.6 cm
16.5 cm
4.1 cm
0.7 kg
Optical Storage
Read Speed
Write Speed
Supported Media Formats
CD-DA (audio), DVD-Video
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Media Load Type
Tray
Access Time
125 ms (CD), 145 ms (DVD-ROM)
Emergency disc eject hole
1 x Serial ATA-150 - 7 pin Serial ATA
Compatible Bay
1 x 5.25" x 1/2H - front accessible
NOM, ICES-003 Class A, FCC Part 15 A
IBM Express Seller
Software Included
Drivers & Utilities
Limited warranty - 1 year
5 °C
45 °C
15 - 80% (non-condensing)
Lenovo System x3100 M3 , Lenovo System x3400 M2 , Lenovo System x3400 M3 , Lenovo System x3550 M2 , Lenovo System x3550 M3 , Lenovo System x3650 M2 , Lenovo System x3650 M3 , Lenovo System x3850 X5
