IBM Multi-Burner is one drive that now does it all. It reads and writes both DVDs and CDs. This high-capacity read/write removable storage solution is perfect for file sharing, backup, audio CD creation, software installations and DVD video playback.
- Lenovo Multi-Burner Drive DVD±RW (±R DL) / DVD-RAM drive - Serial ATA - internal
- DVD±RW (±R DL) / DVD-RAM drive - internal
- Interface
- Serial ATA
- 14.6 cm x 16.5 cm x 4.1 cm
- 0.7 kg
- Optical Storage
- DVD±RW (±R DL) / DVD-RAM - 5.25" x 1/2H
- Read Speed
- 40x (CD) / 16x (DVD)
- Write Speed
- 40x (CD) / 16x (DVD±R) / 8x (DVD±R DL)
- CD / DVD Rewrite Speed
- 32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
- Media Load Type
- Tray
- Manufacturer Selling Program
- IBM Express Seller
- 1-year warranty
- Designed For
- System x3100 M3; x3400 M2; x3400 M3; x3550 M2; x3550 M3; x3650 M2; x3650 M3; x3850 X5
- Interface
- Serial ATA
- 14.6 cm
- 16.5 cm
- 4.1 cm
- 0.7 kg
Optical Storage
- Read Speed
- Write Speed
- Supported Media Formats
- CD-DA (audio), DVD-Video
- Supported Media Types
- CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
- Media Load Type
- Tray
- Access Time
- 125 ms (CD), 145 ms (DVD-ROM)
- Emergency disc eject hole
- 1 x Serial ATA-150 - 7 pin Serial ATA
- Compatible Bay
- 1 x 5.25" x 1/2H - front accessible
- NOM, ICES-003 Class A, FCC Part 15 A
- Software Included
- Drivers & Utilities
- Limited warranty - 1 year
- 5 °C
- 45 °C
- 15 - 80% (non-condensing)
- Designed For
- Lenovo System x3100 M3 , Lenovo System x3400 M2 , Lenovo System x3400 M3 , Lenovo System x3550 M2 , Lenovo System x3550 M3 , Lenovo System x3650 M2 , Lenovo System x3650 M3 , Lenovo System x3850 X5
