- Lenovo - DDR3 - module - 4 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - registered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1333 MHz (PC3-10600)
- Latency Timings
- CL9
- Single rank, Low Voltage, registered
- OEM Manufacturer Equivalent Part Number
- IBM 90Y4551
- Designed For
- System x3300 M4 7382; x3400 M3 7378, 7379; x3500 M3 7380; x3620 M3 7376; x3650 M3 7945
- Capacity
- 4 GB
- Upgrade Type
- System specific
- IBM 90Y4551
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL9
- ECC
- Chips Organization
- X4
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- Lenovo System x3300 M4 7382 , Lenovo System x3400 M3 7378, 7379 , Lenovo System x3500 M3 7380 , Lenovo System x3620 M3 7376 , Lenovo System x3650 M3 7945
