HPE Ultrium Universal Cleaning Cartridge - LTO Ultrium - orange - cleaning cartridge
Quicklinx: 22TMWS00 Mfr#: C7978A
Type: LTO Ultrium
Native Capacity: [N/A]
More than 50 In Stock
£36.29 ex VAT
£43.54 inc VAT
Although HP media offers extreme reliability under a whole range of conditions, it is still advisable to follow a sensible procedure when handling and storing cartridges in order to maximize the life of your tapes. Many causes of recording or read errors are temporary and can be corrected by cleaning cartridge. Regular drive cleaning is essential to long-term reliability and should be conducted on a scheduled cycle as well as when requested by the drive.
This Universal Ultrium cleaning cartridge is designed for use with HP Ultrium drives shipped after January 2002 and for older drives with a firmware upgrade.
  • Highest Capacity and Performance of any Comparable Tape Technology
    HPE LTO-8 Ultrium can write or read data at a blistering 2.7 TB/hour, storing, encrypting and protecting up to 30 TB on a single cartridge, making it ideal for large-scale, 24 x 7, mission-critical IT environments (assumes 2.5:1 compression).An 85% increase in the number of tracks and a 8% increase in bit density has permitted an increase in capacity from 15 TB for LTO-7 to 30 TB to LTO-8: from 3,584 tracks for LTO-6 to 6,656 tracks for 8th generation HPE LTO-8 Ultrium 30 TB cartridges (assuming 2.5:1 compression).HPE LTO Ultrium cartridge memory chip delivers faster access time and enhanced media monitoring.First time restore ensured with fewer media failures and disrupted backups, regardless of duty cycle or environmental conditions.
  • Ultra-reliable
    Tape is more reliable than Enterprise SATA disk. With a BER of 1x10 to the power of 19 for LTO-8 versus 1x10 to the power of 15 for Enterprise SATA HDD's. That's a difference in reliability of four orders of magnitude – e.g. tape is 10,000 times more reliable than Enterprise SATA HDD.Estimated data loss over 10-years for 1 PB archive is 1.1 TB for Enterprise HDD versus 7.4 TB for LTO-8 tape.Superior 'smart grabber' mechanism and mechanical interlock to prevent the leader pin from being pulled inside the tape housing. Sensors detect proper connection and prevent leader loss that would ruin the tape. Simplified tape path to reduce wear, tear & build-up of debris (important in automation).HPE brand qualification test procedures (load/unload, shoeshine, drop testing and environmental stress testing) go far beyond what is required for the LTO Ultrium logo.This ensures maximum reliability for restoring your data.HPE warrants LTO Ultrium cartridges for up to 30 years archival life. This ensures businesses can meet the ever-increasing demands of regulation for data retention and archiving.
  • Secure
    Write-Once-Read-Many (WORM) version provides tamper-proof, compliant data storage.Data encryption for enhanced data security on HP LTO-4, LTO-5, LTO-6, LTO-7 and LTO-8 Ultrium. Compliance with FIPS 140-2 level 1 security standards.
  • Value for money
    Standardizing on HPE LTO Ultrium delivers the capacity to meet shrinking backup windows, industry-standard, AES 256-bit encryption (IEEE1619.1), and interchangeable RW or WORM media; without extra space or IT resource overhead.Open standard technology ensures compatibility across product generations and gives you more choice. Cartridges are available as Custom Labeled, Non-Custom Labeled (both Custom and Non Custom include RFID options for some formats) and non-labeled versions.
HPE Ultrium Universal Cleaning Cartridge - LTO Ultrium x 1 - cleaning cartridge
Cleaning cartridge - LTO Ultrium
Media Included Qty
1
Orange
90 days warranty
HPE MSL2024, MSL4048, T950, T950 3, T950 6; LTO-5 Ultrium; StorageWorks MSL2024, MSL4048, MSL6000, MSL6030, MSL6060, MSL8096, SAS Rack-Mount Kit, SB1760; StorageWorks 1/8 G2 Tape Autoloader; StoreEver MSL2024, MSL3040, MSL4048, MSL4048 LTO-5, MSL6480; SureStore Ultrium; Ultrium 448, 920
Media Included Qty
1
Orange
11.2 cm
2.79 cm
11.3 cm
230 g
90 days warranty
HPE MSL2024 Ultrium 1760, MSL2024 Ultrium 1840, MSL2024 Ultrium 3000, MSL2024 Ultrium 3280, MSL2024 Ultrium 920, MSL4048 Ultrium 1760, MSL4048 Ultrium 1840, MSL4048 Ultrium 3000, MSL4048 Ultrium 3280, T950 3 Drive Bay Assembly Expansion Frame, T950 6 Drive Bay assembly, T950 6 Drive Bay Assembly Expansion Frame, T950 LTO Media Expansion Frame , HPE LTO-5 Ultrium 3000 , HPE StorageWorks ESL9322, ESL9595L1, MSL2024, MSL2024 Ultrium 1760, MSL2024 Ultrium 1840, MSL2024 Ultrium 3000, MSL2024 Ultrium 3280, MSL2024 Ultrium 448, MSL2024 Ultrium 920, MSL2024 Ultrium 960, MSL4048, MSL4048 Ultrium 1760, MSL4048 Ultrium 1840, MSL4048 Ultrium 3000, MSL4048 Ultrium 3280, MSL4048 Ultrium 448, MSL4048 Ultrium 920, MSL4048 Ultrium 960, MSL6000 Ultrium 1840, MSL6030, MSL6030 Ultrium 1840, MSL6030 Ultrium 460, MSL6030 Ultrium 960, MSL6060 Ultrium 1840, MSL6060 Ultrium 460, MSL6060 Ultrium 960, MSL8096 Ultrium 1840, MSL8096 Ultrium 920, MSL8096 Ultrium 960, SAS Rack-Mount Kit, SB1760c Tape Blade , HPE StorageWorks 1/8 G2 Tape Autoloader Ultrium 448, Ultrium 920 , HPE StorageWorks 1/8 Tape Autoloader Ultrium 230, Ultrium 460 , HPE StorageWorks Ultrium 232, 232 Trade-Ready, 448, 448 Array Module, 460, 920, 960 , HPE StoreEver MSL2024 Ultrium 15000, MSL2024 Ultrium 3000, MSL2024 Ultrium 6250, MSL3040 Scalable Library Base Module, MSL3040 Scalable Library Expansion Module, MSL4048, MSL4048 LTO-5 Ultrium 3000, MSL4048 Ultrium 15000, MSL4048 Ultrium 3000, MSL4048 Ultrium 6250, MSL6480 Scalable Base Module, MSL6480 Scalable Expansion Module , HPE SureStore Ultrium , HPE Ultrium 448, 920
Type: LTO Ultrium
Brand: HPE
