HPE LTO-5 Ultrium 3000 SAS Internal Tape Drive
Quicklinx: 8CVWWS00 Mfr#: EH957B
HPE StoreEver LTO Ultrium Tape Drives represent seven-generations of LTO technology capable of storing up to 15 TB per cartridge, with HPE TapeAssure for manageability, hardware data encryption, HPE StoreOpen with LTFS for ease of use at an unprecedented performance. With HPE TapeAssure customers can be confident that their data is safe by monitoring drive and media utilization, operational performance and life/health information for drive and media. Data hardware encryption using AES 256-bit provides easy-to-enable security to protect the most sensitive data and prevent unauthorized access of tape cartridges. Linear Tape File System (LTFS) is an open format for storing data on tape that makes LTO generation 5 and later tapes self-describing and file-based. Capable of data transfer rates up to 300 MB/sec native, HPE's Data Rate Matching further optimizes performance by matching host system speed to keep drives streaming, thus enabling the fastest tape performance.
  • Outstanding Capacity and Performance, Monitoring Capabilities, Hardware Encryption & StoreOpen/LTFS
    HPE StoreEver LTO Ultrium Tape Drives provide up to 30TB of compressed capacity on a single cartridge.HPE StoreOpen Standalone and Linear Tape File System (LTFS) allows customers to store data in an open format making the tape self-describing and file-based.Enables even the tightest backup window to be met with unprecedented performance.Provides highest level of security with encryption for strong backup data privacy to secure confidential information and address compliance quickly and with fewer cartridges.
  • Reliable, Well Connected and Compatible
    Allows the tape drive to continuously adjust the speed of the drive to keep drives streaming to maximize performance and reduce start/stops which significantly increase reliability of HPE drives and media.SAS models qualified on HPE and non-HPE servers; including popular platforms from vendors such as Dell, IBM, and Sun. See DAPR compatibility matrix on the right rail for more information.Extensive list of supported backup and archiving software applications from HPE, CA, VERITAS, Legato, Tivoli, and many more.Design leveraged from previous HPE LTO tape drives to deliver confident backups at high duty cycles.
  • Complete Solution Straight out of the Box
    Provides HPE LTO media, cables, user guides and a download flyer for the fully functional 60-day trial of Veritas Backup Exec. Customers can receive a 50% discount off Veritas MSRP.For IT organizations with stringent, long-term data retention requirements, WORM data protection capability offers a simple and secure method for archiving records allowing customers to affordably meet the toughest industry compliance regulations.
HPE LTO-5 Ultrium 3000 - tape drive - LTO Ultrium - SAS-2
Tape drive
Recording Standard
LTO Ultrium 5
Enclosure Type
Internal
Interface Type
SAS-2
Key Features
Encryption
14.5 cm x 20.6 cm x 4.1 cm
1.45 kg
Storage Removable
LTO Ultrium - 5.25" x 1/2H
Storage Removable Capacity
1.5 TB (native) / 3 TB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 4, Ultrium 5
Data Transfer Rate (native)
140 MBps (504 GBph)
Data Transfer Rate (compressed)
280 MBps (1008 GBph)
IBM AIX, SunSoft Solaris, HP-UX, Red Hat Linux, SuSe Linux, Microsoft Windows, HP Tru64 UNIX
3-year warranty
ProLiant DL360e Gen8, DL360p Gen8, DL370 G6, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, ML110 G6, ML110 G7, ML150 G6, ML310e Gen8, ML330 G6, ML350 G6, ML350e Gen8, ML350p Gen8; StorageWorks Rack-Mount Kit Ultrium 1760
Tape drive - LTO Ultrium
Recording Standard
LTO Ultrium 5
Enclosure Type
Internal
Interface Type
SAS-2
Key Features
Encryption
14.5 cm
20.6 cm
4.1 cm
1.45 kg
Storage Removable
Recording Standard
140 MBps (504 GBph)
Buffer Size
256 MB
1 x SAS-2 - 29 pin internal SAS (SFF-8482)
Compatible Bay
1 x front accessible - 5.25" x 1/2H
Media Included Qty
1
1 x SAS cable
MTBF
250,000 hour(s)
TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, FCC CFR47 Part 15, AES-256
Software Included
Drivers & Utilities, Yosemite Backup Basic, HP Library and Tape Tools
Limited warranty - 3 years - response time: next day , Technical support - phone consulting - 3 years
10 °C
20 - 80% (non-condensing)
HPE ProLiant DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL370 G6 Base, DL370 G6 High Performance, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL385p Gen8 Storage Centric, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, ML110 G6, ML110 G7, ML150 G6, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML330 G6, ML350 G6, ML350 G6 Base, ML350 G6 Performance, ML350 G6 Special Server, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350p Gen8, ML350p Gen8 Base, ML350p Gen8 Entry, ML350p Gen8 Performance, ML350p Gen8 Special Server , HPE StorageWorks Rack-Mount Kit Ultrium 1760 Drive
8CVW HPE Ultrium Universal Cleaning Cartridge - LTO Ultrium - orange - cleaning cartridge In Stock £35.67
