HPE HP - DAT-72 - 36 GB / 72 GB - blue - storage media
Quicklinx: 2P9DWS00 Mfr#: C8010A
With an installed base of more than 19 million drives and 6 million users, DDS/DAT is easily the world's most popular tape storage format. The latest generation of this simple and successful format is delivered by the HP DAT 320 tape storage solution, providing a 12 MB/sec transfer rate and up to 320 GB capacity on a single cartridge. New manufacturing and recording technologies have created a tough, lightweight, high capacity, high performance media that more than measures up to the uncompromising storage demands of today's dynamic, risk-aware businesses. DDS/DAT provides a reliable, low-cost, easy-to-use backup solution for small to medium-sized businesses to meet increasing storage demands and compliance criteria. A Storage Media Kit is also available, providing a complete tape media solution in one easy to buy product.
  • Familiar, Low-risk Format Ideal for Small and Medium-sized Backup Environments
    DAT has a global installed base of more than 1.9 million drives, making it the favorite backup solution among small and medium sized organizations.Latest HP DAT 320 solutions feature new tape technology for better performance and higher capacity in increasingly demanding backup environments, while retaining media compatibility and interchange with DAT 160.HP DDS-DAT media are available with capacities from 40 GB (DDS-3) through to 320 GB compressed (DAT 320). Up to 86.4 GB/hour can be stored with DAT 320.HP has 76% of the market and an installed base of more than 1.3 million drives.
  • Value for Money
    Lower cost of ownership for small and medium sized organizations compared with AIT and DLT VS with a superior cost per GB.New wide format (DAT 160 and DAT 320) provides a longer tape with greater capacity. Few tape swaps and higher capacity cartridges mean a smaller footprint for backup and archiving and less downtime and operator invention.Backwards compatibility and a confirmed development roadmap offer sustained ROI and migration to higher capacities to meet growing storage demands.
  • Simple, Practical, Out-of-the-box Solution
    The USB model can be out of the box and ready to go in under 60 seconds.HP One-Button Disaster Recovery (OBDR) Solution supports HP DAT media on HP DDS/DAT drives. With OBDR you can quickly, reliably and simply restore your entire system by inserting the most recent backup tape and pushing a button the tape drive.Supports the full range of HP tools and software for smooth, effective backup and rapid fault diagnosis and resolution. A Storage Media Kit is also available, providing a complete tape media solution in one easy to buy product.
  • Exhaustively Qualified and Warranted for Use with HP and Non-HP DAT Products
    A continuous testing program in HP's media laboratory guarantees maximum restore performance. 70,000 tests and 1.3 million test hours a year emulate real-world environmental conditions and usage to ensure every tape works reliably the first time and every time.HP warrants DAT cartridges for up to 30 years archival life. This ensures businesses can meet the ever-increasing demands of regulation for data retention and archiving.
HPE - DAT DAT-72 x 1 - 36 GB - storage media
Storage media - DAT
Tape Cartridge
DAT-72
Media Included Qty
1
Blue
Native Capacity
36 GB
Compressed Capacity
72 GB
Tape Length
170 m
HPE DAT 72; StorageWorks DAT 160, DAT 72, DAT 72m, DAT 72x6; StorageWorks Rack-Mount Kit DAT 160; Trade-Ready Tape Drive DAT 72
DAT
Tape Cartridge
DAT-72
Media Included Qty
1
Blue
Media
Native Capacity
36 GB
Compressed Capacity
72 GB
Tape Length
170 m
Archival Life
20 years
5 °C
45 °C
20 - 80%
Min Storage Temperature
5 °C
Max Storage Temperature
32 °C
Humidity Range Storage
20 - 60%
HPE DAT 72 USB Internal Tape Drive , HPE StorageWorks DAT 160 Array Module, DAT 160 External Tape Drive, DAT 160 Internal Tape Drive, DAT 160 USB External Tape Drive, DAT 160 USB Internal Tape Drive, DAT 72 Array Module, DAT 72 External Tape Drive, DAT 72 Hot-Plug Tape Drive, DAT 72 Internal Tape Drive, DAT 72 Trade-Ready, DAT 72 USB External Tape Drive, DAT 72 USB Internal Tape Drive, DAT 72m Array Module, DAT 72x6 Autoloader , HPE StorageWorks Rack-Mount Kit DAT 160 drive , HPE Trade-Ready Tape Drive DAT 72
