USB Standard Keyboards represent a design extension of the successful Easy Access keyboards. Expanded configurability by allowing the keyboard to sit upon the desk at either zero-degree (flat), 6-degree or 12-degree slope through the use of the keyboards tilt legs.
- HPE Standard - keyboard - UK Input Device
- Keyboard
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- 45.8 cm x 16.3 cm x 2.5 cm
- 0.9 kg
- Pricing Type
- Promo
- Keyboard
- Interface
- USB
- UK
- Region
- United Kingdom
- Keyboard Technology
- Membrane
- 45.8 cm
- 16.3 cm
- 2.5 cm
- 0.9 kg
- Connections
- 1 x USB - 4 pin USB Type A
- Cables Included
- 1 x USB cable - 1.8 m
- FCC Class B certified, CSA, UL, TUV, ANSI-HFS-100, TUV GS, VCCI, ISO 9241-4, C-Tick, BSMI, MIC
- Pricing Type
- Promo
- OS Required
- Microsoft Windows 2000 / XP, Microsoft Windows Vista Home Basic, Microsoft Windows Vista Business, Microsoft Windows Vista Business 64-bit Edition
- 10 °C
- 50 °C
- 10 - 90%
- Sound Emission
- 43 dBA
