Now you can set your keyboard on your desk at either zero-degree (flat), 6-degree or 12-degree slopes with tilt legs on HP standard keyboards to maximize your comfort. HP standard keyboards are also more ecologically friendly as the painted surface has been minimized to a removable silver accent strip around the top-row function keys.
- HP Standard - keyboard
- Keyboard - wired
- Interface
- USB
- Localisation
- English - United Kingdom
- 45.8 cm x 16.3 cm x 2.5 cm
- 0.9 kg
- Pricing Type
- Promo
- Designed For
- Compaq 100; HP 4000, 50X, 6200, 8200; All-in-One 100; Elite 7200; Point of Sale System rp5800; Pro 31XX, 33XX; ProLiant BL460c G7, BL465c G7, BL490c G7, BL620C G7, BL680c G7, BL685c G7, DL165 G7, DL380 G7, DL385 G7, DL585 G7, MicroServer; Thin Client t5550, t5565, t5570, t5740; Workstation z210
- Keyboard - wired
- Interface
- USB
- Localisation
Input Device
- Keyboard Technology
- Membrane
- 45.8 cm
- 16.3 cm
- 2.5 cm
- 0.9 kg
- Connections
- 1 x USB - 4 PIN USB Type A
- Cables Included
- 1 x USB cable - 1.8 m
- FCC Class B certified, CSA, UL, TUV, ANSI-HFS-100, TUV GS, VCCI, ISO 9241-4, C-Tick, BSMI, MIC
- Pricing Type
- Promo
- OS Required
- Microsoft Windows 2000 / XP, Microsoft Windows Vista Home Basic, Microsoft Windows Vista Business, Microsoft Windows Vista Business 64-bit Edition
- 10 °C
- 50 °C
- 10 - 90%
- Sound Emission
- 43 dBA
- Designed For
- Compaq 100B , HP 500B, 550 , HP All-in-One 100B , HP Elite 7000, 7100, 7200 , HP EliteBook 2530p, 2730p, 6930p, 8530p, 8530w, 8730w , HP Point of Sale System rp5800 , HP Pro 2000, 3000, 3005, 3010, 3015, 3120, 3125, 3130, 3135, 3300, 3305 , HP ProLiant BL460c G7, BL465c G7, BL490c G7, BL620C G7, BL680c G7, BL685c G7, DL160 G5, DL160 G6, DL160se G6, DL165 G5p, DL165 G5p Base, DL165 G5p Efficiency, DL165 G5p Entry, DL165 G5p Performance, DL165 G6, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL170h G6, DL180 G6, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Performance, DL370 G6, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL385 G5 Carrier-Grade, DL385 G5p, DL385 G5p Entry, DL385 G5p High Performance, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL585 G5 High Performance, DL585 G6, DL585 G6 Base, DL585 G7, DL585 G7 Base, DL585 G7 Performance, MicroServer, ML110 G6, ML110 G6 Base, ML110 G6 Performance, ML150 G5, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL165z G6, SL165z G7 , HP Thin Client st5548, st5738, t5145, t5325, t5540, t5545, t5550, t5565, t5570, t5630, t5630w, t5740, t5740e, vc4820T, vc4825T , HP TouchSmart dx9000 , HP Workstation z210, z400, z600, z800 , HP Compaq 4000 Pro, 500B, 505B, 6000 Pro, 6005 Pro, 6200 Pro, 6530b, 6720s, 6730b, 6730s, 6735b, 6830s, 8200 Elite, 8200 Elite USDT PC, Elite 8000, Elite 8000f, Elite 8100 , HP Compaq Business Desktop dx2040, dx2420, dx2810, dx7510 , HP Compaq Thin Client gt7720, t5540, t5545, t5630, t5630w, t5730w
