HP StorageWorks LTO-4 Ultrium 1840 Tape Drive represents HP's fourth-generation of LTO tape drive technology positioned as HP's first tape drive capable of storing up to 1.6TB per cartridge while providing hardware-based encryption to enable greater levels of security and unprecedented performance. Data hardware encryption using AES 256-bit provides easy-to-enable security to protect the most sensitive data and prevent unauthorized access of tape cartridges. By using LTO-4 Ultrium 1840 encryption, not only is data fully capable of being compressed therefore maximizing capacity, encrypted backups are completed without a loss in performance.Capable of data transfer rates up to 240MB/sec, HP's exclusive Data Rate Matching feature further optimizes performance by matching host system speed to keep drives streaming and enabling the fastest tape performance in the industry.
- HPE StorageWorks Ultrium 1840 - tape drive - LTO Ultrium - SCSI
- Tape drive
- Recording Standard
- LTO Ultrium 4
- Enclosure Type
- Internal
- Interface Type
- SCSI LVD
- 14.6 cm x 20.3 cm x 8.3 cm
- 2.2 kg
- Storage Removable
- LTO Ultrium - 5.25" x 1H
- Storage Removable Capacity
- 800 GB (native) / 1.6 TB (compressed)
- Supported Tape Cartridges (Read and Write)
- Ultrium 3, Ultrium 4
- Data Transfer Rate (native)
- 120 MBps (432 GBph)
- Data Transfer Rate (compressed)
- 240 MBps (864 GBph)
- OS Required
- IBM AIX, SunSoft Solaris, HP-UX, Red Hat Linux, SuSe Linux, Microsoft Windows, HP Tru64 UNIX
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Designed For
- ProLiant DL370 G6, ML150 G3, ML150 G5, ML310 G3, ML350 G4, ML350 G5, ML350 G6, ML370 G4, ML370 G5
- Tape drive - LTO Ultrium
- LTO Ultrium 4
- Enclosure Type
- Internal
- Interface Type
- SCSI LVD
- 14.6 cm
- 20.3 cm
- 8.3 cm
- 2.2 kg
Storage Removable
- Capacity
- Buffer Size
- 128 MB
- 1 x Ultra320 SCSI LVD - 68 pin IDC
- Compatible Bay
- 1 x front accessible - 5.25" x 1H
- Media Included Qty
- 1
- Included Accessories
- Cleaning cartridge
- Cables Included
- 1 x SCSI cable
- MTBF
- 250,000 hour(s)
- TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, FCC CFR47 Part 15
- Software Included
- Drivers & Utilities, HP OpenView Storage Data Protector, HP StorageWorks Library and Tape Tools
- OS Required
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 20 - 80%
- Designed For
- HPE ProLiant DL370 G6 Base, DL370 G6 High Performance, ML150 G3, ML150 G5, ML150 G5 Base, ML150 G5 Performance, ML310 G3, ML310 G3 1 TB Storage Server, ML310 G3 2 TB Storage Server, ML310 G3 320 GB Storage Server, ML310 G3 640 GB Storage Server, ML310 G3 Data Protection Storage Server, ML310 G3 Data Protection Storage Server Model 1 TB, ML310 G3 Data Protection Storage Server Model 2 TB, ML310 G3 Data Protection Storage Server Model 320 GB, ML310 G3 Data Protection Storage Server Model 640 GB, ML350 G4, ML350 G4 Storage Server Base Model, ML350 G4 Storage Server Int SCSI Storage Model, ML350 G5, ML350 G5 1.5 TB Storage Server, ML350 G5 1.8TB SAS Storage Server, ML350 G5 3 TB Storage Server, ML350 G5 960 GB Storage Server, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Performance, ML350 G6 Special Server, ML370 G4, ML370 G4 1.2 TB Storage Server, ML370 G4 High Performance, ML370 G4 Storage Server Base Model, ML370 G4 Storage Server High Performance Model, ML370 G4 Storage Server Int SCSI Storage Model, ML370 G5, ML370 G5 Base, ML370 G5 Entry, ML370 G5 High Performance, ML370 G5 Performance
